rocco Posted October 18, 2007 Share Posted October 18, 2007 Hi all, i'm curious if other owners have noticed the same shifter rattle as my car has been producing lately under light acceleration or simply revving it a bit in neutral. The dealer has looked into it and has found nothing. Any insight into this? Alex Link to comment Share on other sites More sharing options...
spicytuna Posted October 18, 2007 Share Posted October 18, 2007 Shifter rattle? My 5spd shifter vibrates when driving but it doesn't exactly rattle. Do you have any shifter mods? Like a short shifter? Link to comment Share on other sites More sharing options...
VtspecB Posted October 18, 2007 Share Posted October 18, 2007 I had a rattle at 55mph+. I have the Cobb STS installed. I pulled the boot and noticed that the nut on the bolt that holds the shifter to the linkage had come loose so that the nut/bolt assy rattled during just the right combination of variables. my vBGarage Link to comment Share on other sites More sharing options...
Underdog Posted October 18, 2007 Share Posted October 18, 2007 I had a rattle with my Cobb STS that I fixed by lubing the pin pivot (not the ball pivot) with standard lithium grease. Symptoms were present during aggresive acceleration and coasting at anything over 3k rpm. I drove around for a day or two with the shifter trim removed and narrowed it down by pressing at certain points to isolate the noise. The Crimson Dynamo Link to comment Share on other sites More sharing options...
VtspecB Posted October 18, 2007 Share Posted October 18, 2007 I drove around for a day or two with the shifter trim removed and narrowed it down by pressing at certain points to isolate the noise. ... same here my vBGarage Link to comment Share on other sites More sharing options...
rocco Posted October 19, 2007 Author Share Posted October 19, 2007 I drove around for a day or two with the shifter trim removed and narrowed it down by pressing at certain points to isolate the noise. i'll do that after work and see where it leads me. Only mod is the Hardened shifter bushings from Cobb. Thanks for all the responses guys. Alex Link to comment Share on other sites More sharing options...
