evilla84 Posted October 7, 2007 Share Posted October 7, 2007 Hello, I'm a new member and I'm finally going to upgrade my headlights to HIDs. Sorry if this has been addressed before in past postings, but I haven't been able to find the exact solution to my problem. I'm running DRLs on my Legacy 06 and I want to disable them so that it doesn't shorten the life of the HIDs when I put them in. Some postings mention pulling a plug under the hood. Some mention that it's better to disconnect the white plug behind the glove box or below the steering wheel. I'm not really well versed with these things so I would appreciate if someone could direct me to which plug is best to pull and where I can locate it. Any pictures you may have would be most helpful as well. Thanks in advance. Link to comment Share on other sites More sharing options...
LGT Dave Posted October 7, 2007 Share Posted October 7, 2007 The DRL module with the plug you need to disconnect is under the steering column. See here: http://www.legacygt.com/forums/showthread.php?t=2117. Link to comment Share on other sites More sharing options...
evilla84 Posted October 8, 2007 Author Share Posted October 8, 2007 Thanks I really appreciate it! Link to comment Share on other sites More sharing options...
edekba Posted October 9, 2007 Share Posted October 9, 2007 Very easy to do. I did it in under 10min. Hardest part was doing it at noon, and pulling the white bracket. Broke out in a sweat. That's all Link to comment Share on other sites More sharing options...
NOTATURBO Posted October 9, 2007 Share Posted October 9, 2007 just be glad you don't have an 07....we have to cut a wire to disable them... Link to comment Share on other sites More sharing options...
edekba Posted October 9, 2007 Share Posted October 9, 2007 oucH! Link to comment Share on other sites More sharing options...
