moshulu Posted September 20, 2007 Share Posted September 20, 2007 Can someone explain the meaning of those graphs that show up inside the tachometer dial on my 3.0R? What are the axes? I assume the x-axis is throttle setting (pedal displacement), but what is plotted on the y-axis? Why do the three curves (I, S, S#) break and plateau differently? Is it the highlighted AREA under the curve that measures something (power? torque?). Or is the whole display just techy-looking BS? moshulu Link to comment Share on other sites More sharing options...
Underdog Posted September 20, 2007 Share Posted September 20, 2007 I believe it is a map of throttle plate position (y-axis) versus the gas pedal position (x-axis). It is also probably just techy looking and not representative of the actual curves. The Crimson Dynamo Link to comment Share on other sites More sharing options...
