05LegacyLIMITED Posted September 9, 2007 Share Posted September 9, 2007 hey guys, i sold my AP which means I unmarried it of course, and while driving it home lastnight the check engine light came on and the cruise control light is blinking..... All that is on my car is a high flow air filter, cobb dp, light weight pulley...... what is going to happen since i no longer have any engine tuning..... Link to comment Share on other sites More sharing options...
meier motor sports Posted September 9, 2007 Share Posted September 9, 2007 who knows. is your down pipe catless? Link to comment Share on other sites More sharing options...
BigBad Posted September 9, 2007 Share Posted September 9, 2007 Down pipe will cause that. Doesn't matter if its catted or uncatted. The cobb accessport turns off those cels. I would be concerned about boost creep with a stage 2 setup and no tuning device. Link to comment Share on other sites More sharing options...
05LegacyLIMITED Posted September 9, 2007 Author Share Posted September 9, 2007 yes i am catless.......what is the solution? other then uninstalling the downpipe? and other then possible boost creep, there are no worries? Link to comment Share on other sites More sharing options...
meier motor sports Posted September 9, 2007 Share Posted September 9, 2007 yes i am catless....... i no longer have any engine tuning..... lastnight the check engine light came on and the cruise control light is blinking..... i think we have a suficient answer Link to comment Share on other sites More sharing options...
BigBad Posted September 9, 2007 Share Posted September 9, 2007 I don't know of a solution to the cels with the aftermarket downpipe with out tuning assist. Technically you can run it like that. Why did you get rid of your AP? Link to comment Share on other sites More sharing options...
05LegacyLIMITED Posted September 9, 2007 Author Share Posted September 9, 2007 I got rid of the AP because i thought i was going to have no choice but to get rid of the legacy. so i was in the process of reverting the whole car back to stock. Then everything turned around for me, but I already cashed a check for the AP.....the rest of the stuff is staying on! so your saying nothing will get hurt by running the car the way it is currently? Link to comment Share on other sites More sharing options...
meier motor sports Posted September 9, 2007 Share Posted September 9, 2007 im sure the car isnt running the way it should. some one who has tuned a legacy and knows what a data log for this would look like could tell ya. Link to comment Share on other sites More sharing options...
dr. pepper Posted September 9, 2007 Share Posted September 9, 2007 If you're keeping the leggy, buy another AP! A pulley and a catless downpipe potentially could cause problems if you aren't tuned for them anymore. Link to comment Share on other sites More sharing options...
BigBad Posted September 9, 2007 Share Posted September 9, 2007 Yes you can run it like that with the cels but I wouldn't for the long term because of the boost creep issue. If it goes into uncontrolled boost you could damage your engine. Link to comment Share on other sites More sharing options...
05LegacyLIMITED Posted September 9, 2007 Author Share Posted September 9, 2007 thats what i was wondering dr.pepper. i think i have no choice but to buy another accessport, however it will be a little while before i can do that......so i am hoping i can drive it the way it is for a littlebit Link to comment Share on other sites More sharing options...
NSFW Posted September 9, 2007 Share Posted September 9, 2007 Check out the open source tools too. Link to comment Share on other sites More sharing options...
boostsr20 Posted September 9, 2007 Share Posted September 9, 2007 Check out the open source tools too. Yup. You can turn off all the CE lights that matter with your setup. Just read up on it a little. Its not hard to do and as long as you don't make any crazy chanegs and keep datalogging you'll be safe. Link to comment Share on other sites More sharing options...
05LegacyLIMITED Posted September 9, 2007 Author Share Posted September 9, 2007 boostsr20 i have been reading up on enginunity.com and that seems to be the best quick fix for me.....Just a little nervous that i may turn the wrong things on/off Link to comment Share on other sites More sharing options...
boostsr20 Posted September 9, 2007 Share Posted September 9, 2007 Look in the tuning portion of the forum. Mickey just helped out Big Honu in setting up his stage 1 map. That would be a safe base map for you to start from. You'll need to get a tactrix cable and follow these steps. 1.Use ECUflash to pull the Rom off your ECU. This will tell you which ECU code to use. 2. Use enginuity to modify the map or if you have the same ECU code as big Honu then you can simply load his map to your ECU through ECUflash. Here are Stock ROM's if you know your ECU code off hand you can start transferring Big Honu's values over. You'll need to register for this link to work. Rom files are listed as .hex http://www.xpttuning.com/osecuroms/viewforum.php?f=22 Also, make sure that all the diagnostic codes that cobb normally shuts off are checked off. 3. Once you get the map setup how you want it then you can save it to a new name so you still have your original ROM unmolested if you need to go back to it. Then use ECU flash to flash it to your ROM. I think ECU Flash is bundled with Enginuity when you D/L it. Not 100% though, I'd start with downloading Enginuity and see. Before you start flashing maps and reading your ROM make sure to read through all the FAQ's on enginuity's site. If you don't know what a function does, don't change it. Research it and fully understand it before messing with it. Thats how people get into trouble. A stage 2 map is fairly straight forward though. Once you get into CAI and injector changes then it gets a little more involved. Link to comment Share on other sites More sharing options...
boostsr20 Posted September 9, 2007 Share Posted September 9, 2007 These are the CE codes that normally get shut off on a COBB map. P0137 - Rear O2 Sensor Low Voltage P0138 - Rear O2 Sensor High Voltage P0139 - Rear O2 Sensor Slow Response P0420 - Catalyst System Efficiency Below Threshold P0545 - EGT Sensor Circuit Low P0546 - EGT Sensor Circuit High P1301 - Misfire Detected (High Temp Exhaust Gas) P1312 - EGT Sensor Malfunction P2096 - Post Catalyst Too Lean P2097 - Post Catalyst Too Rich Link to comment Share on other sites More sharing options...
05LegacyLIMITED Posted September 10, 2007 Author Share Posted September 10, 2007 thanks for the help!!!!someone told me that there are already a few basic custom maps floating around out there that i could use with enginuity....... where can i find these? Link to comment Share on other sites More sharing options...
boostsr20 Posted September 10, 2007 Share Posted September 10, 2007 I just told you where to find a good base map Link to comment Share on other sites More sharing options...
05LegacyLIMITED Posted September 10, 2007 Author Share Posted September 10, 2007 gotcha!!! Link to comment Share on other sites More sharing options...
MCC Posted February 24, 2008 Share Posted February 24, 2008 I got the code P0139 - Rear O2 Sensor Slow Response does it mean the one on uppipe or on downpipe? Link to comment Share on other sites More sharing options...
boostsr20 Posted February 24, 2008 Share Posted February 24, 2008 The uppipe has an EGT sensor in it. The "front" refers to the o2 in the passenger side exhaust manifold and "rear" refers to the one that is in the second portion of the DP. (Roughly in the middle of the car) Link to comment Share on other sites More sharing options...
