EXBMWFAN Posted September 8, 2007 Share Posted September 8, 2007 Friday my fiance comes home and says the CEL is on. I go look CEL is on and cruise flashing. I go to work today and check the codes on a Mac scanner. ( I work @ a bmw dealer ) My codes are P2004 Intake Manifold Runner Control Stuck Open (Bank 1) P2005 Intake Manifold Runner Control Stuck Open (Bank 2) P2012 Intake Manifold Runner Control Circuit Low (Bank 2) My car is dead stock other than tires and brakes. Has anyone ever brought their Legacy GT 2.5 to a dealer and have them fix anything or just clear the codes and send you on your way. I already know what the codes mean. Tumble valve on the intake manifold. There is a good explanation of the part here http://www.drive.subaru.com/Win03_Manifold.htm So my only question is this. Should I bring to a dealer and waste my time having them run the codes again. Do you think they will replace the valves? I should have used the snap on scanner and check the fault occurance. 2006 TOYOTA TUNDRA 2005 LGT 5EAT 2003 VW GTI - sold. 1991 BMW M3 1972 BMW 2002 Link to comment Share on other sites More sharing options...
EXBMWFAN Posted September 8, 2007 Author Share Posted September 8, 2007 I have read all the other posts that I could find on these codes and didn't see a result on anyones threads. Plus half of them had mods and everone was to concerned about them. 2006 TOYOTA TUNDRA 2005 LGT 5EAT 2003 VW GTI - sold. 1991 BMW M3 1972 BMW 2002 Link to comment Share on other sites More sharing options...
underpowerd Posted September 8, 2007 Share Posted September 8, 2007 <No expert, but my guess would be if you're under warranty, bone stock, the dealer will likely: reflash, see if it stays away; if so, tell you it's a fluke code. if not, i imagine they could be cleaned similar to a throttle body if gunked up and sticking open; probably doubtful they'd go through that trouble, and more likely to just replace if it got that far. finally, they could opt to replace either the tgv assemblies, or just the servos or the sensors. if they clean or replace the valves, it'll be there for a while, as the manifold will need to be lifted to get them out/in. best of luck. Link to comment Share on other sites More sharing options...
slimjoe Posted September 11, 2007 Share Posted September 11, 2007 My '05 LGT threw a P2009 last week and I'm bringing it in on Thursday for the dealer to look at. I'll let you guys know what happens with that after they look at it. Oh yeah, bone stock. Nothing done to the car at all. Link to comment Share on other sites More sharing options...
rc0032 Posted September 11, 2007 Share Posted September 11, 2007 Its the TGV's if this is the first time reset the CEL. If its the second take it in (provided) you are stock) evlse start replacing sensors. Link to comment Share on other sites More sharing options...
slimjoe Posted September 13, 2007 Share Posted September 13, 2007 Well, I brought it in and they didn't do anything to it. Their report on the invoice thing says: History code function test no faults Re-Program call codes clear won't set So yeah, I can't really help you here. I'm still kinda worried though since it's the second time the code has come up and I don't want to deal with a TGV issue when I fall out of warranty, unless that's considered part of the powertrain warranty. Link to comment Share on other sites More sharing options...
Rallitek.com Posted April 6, 2010 Share Posted April 6, 2010 Well, I brought it in and they didn't do anything to it. Their report on the invoice thing says: History code function test no faults Re-Program call codes clear won't set So yeah, I can't really help you here. I'm still kinda worried though since it's the second time the code has come up and I don't want to deal with a TGV issue when I fall out of warranty, unless that's considered part of the powertrain warranty. Have the dealer write an invoice whenever the code happens. If you can prove a history of the problem, Subaru will deal with the repair after the warranty period. (I was a service manager for Subaru for several years...) Sean S. http://www.RalliTEK.com Link to comment Share on other sites More sharing options...
kinder Posted April 7, 2010 Share Posted April 7, 2010 ^ what he said. TGVs would not be covered under the powertrain warrenty. Link to comment Share on other sites More sharing options...
05pearl Posted April 7, 2010 Share Posted April 7, 2010 2 1/2 year old thread bumps FTW. Link to comment Share on other sites More sharing options...
petes99 Posted June 6, 2014 Share Posted June 6, 2014 I'm bumping this one again.. Bone stock here - '05 LGT ltd 5MT wagon @ 109k Lately anytime I drive aggressively, I get the CEL/cruise combo.. pulled my codes today: P2004 Intake Manifold Runner Control Stuck Open (Bank 1) P2005 Intake Manifold Runner Control Stuck Open (Bank 2) P2009 Intake Manifold Runner Control Circuit Low (Bank 1) P2012 Intake Manifold Runner Control Circuit Low (Bank 2) Note its not during startup - the car is usually warm already.. esp today - CEL fired after a 20+ minute drive when I "got on it" on the highway. No power loss or anything like that. Any thoughts? Is this still TGV? Link to comment Share on other sites More sharing options...
RallyMachine Posted June 7, 2014 Share Posted June 7, 2014 When I got my codes I literally unplugged all the TGV motors and sensors and plugged them back in and they haven't returned... *knock on wood* Link to comment Share on other sites More sharing options...
Max Capacity Posted June 7, 2014 Share Posted June 7, 2014 Good idea there, may be its a age related thing, just clean the contacts. The common sense things is, what would cause all to do that at the same time... age and corrosion. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
petes99 Posted June 10, 2014 Share Posted June 10, 2014 Thx guys. Just an update - I cleared the codes and was able to reproduce p2012 this morning. Twice. Ever worth replacing the TGV? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 10, 2014 Share Posted June 10, 2014 It's most likely the solinoid for the drivers side TGV. See what Fredbeans has for a price. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
petes99 Posted July 29, 2014 Share Posted July 29, 2014 Ok, I hate to ask this, but does anyone have a diagram of the TGV plugs/sensors so I can clean/reseat them? My thumbs are quite green in this arena. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 29, 2014 Share Posted July 29, 2014 Ok, I hate to ask this, but does anyone have a diagram of the TGV plugs/sensors so I can clean/reseat them? My thumbs are quite green in this arena. This may help Link to comment Share on other sites More sharing options...
petes99 Posted July 29, 2014 Share Posted July 29, 2014 that's perfect.. thanks!! Link to comment Share on other sites More sharing options...
petes99 Posted August 19, 2014 Share Posted August 19, 2014 So I finally got around to reseating the plugs and no more CELs. Funny. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 20, 2014 Share Posted August 20, 2014 Mine did the same thing. With the ap i can still see .4v on the left and .5 on the right so mine is still having issues even with codes not popping up. Link to comment Share on other sites More sharing options...
diverrick Posted August 19, 2015 Share Posted August 19, 2015 So I finally got around to reseating the plugs and no more CELs. Funny. RESEATING WHICH PLUGS? I have the same issue. Thinking of buying the aftermarket install that removes the whole thing and simply fakes the computer into thinking it has them. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 19, 2015 Share Posted August 19, 2015 Deleted tgv's no more code issues. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted October 7, 2016 Share Posted October 7, 2016 Deleted tgv's no more code issues. Does deleting TGVs cause failed emissions? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted October 7, 2016 Share Posted October 7, 2016 I had the codes removed when i was retuned. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 7, 2016 Share Posted October 7, 2016 Does deleting TGVs cause failed emissions? I'm thinking no. PM Brian at TA and see if he knows. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nightmaresmk Posted October 7, 2016 Share Posted October 7, 2016 Check engine light will fail. you need to have the codes turned off. Link to comment Share on other sites More sharing options...
