korpsepatrol Posted August 29, 2007 Share Posted August 29, 2007 So by installing a catless up-pipe and gutting the dp, would i still be able to pass the NY emissions? Thoughts? Experiences? Motivational Words? 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
korpse Posted August 30, 2007 Share Posted August 30, 2007 So by installing a catless up-pipe and gutting the dp, would i still be able to pass the NY emissions? Thoughts? Experiences? Motivational Words? lol, nice name... i don't think you'd pass, i have 1 high flow cat and it still throws a cel. Link to comment Share on other sites More sharing options...
whitetiger Posted August 30, 2007 Share Posted August 30, 2007 ^thats cause you have no engine management like an accessport. If you have a tune that accounts for the lack of cats and blocks the rear 02 sensor from thowing a code, then you will pass an obdII scan and therefore an emissions test. Link to comment Share on other sites More sharing options...
korpse Posted August 30, 2007 Share Posted August 30, 2007 Thanks for telling me what i have and don't have in my car... If they do a sniffer test you will fail. Even if you have a high flow cat, which was my point, you will probably fail. By your remarks I'm guessing they don't do a sniffer test in NY like they do in NJ. Also, if they do a visual inspection you will fail. You can avoid this by putting a heat shield on your downpipe. ^thats cause you have no engine management like an accessport. If you have a tune that accounts for the lack of cats and blocks the rear 02 sensor from thowing a code, then you will pass an obdII scan and therefore an emissions test. Link to comment Share on other sites More sharing options...
Edvig Posted August 30, 2007 Share Posted August 30, 2007 NYS inspection is an ODBII scan and visual test. You will pass if you have no codes showing. You will pass a visual inspection if you gut your OE pipes. Link to comment Share on other sites More sharing options...
korpsepatrol Posted August 30, 2007 Author Share Posted August 30, 2007 Thanks for the info! Heard the same thing from other members confirming, what whitetiger and edvig say is true. Thanks. and yes our names are great korpse. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx Link to comment Share on other sites More sharing options...
