pengwin Posted August 26, 2007 Share Posted August 26, 2007 Do i have to put premium in if i buy a LGT or can i get away with regular? Will regular cause engine damage or just not put out as many horses? Thanks guys Link to comment Share on other sites More sharing options...
Richard B. Posted August 26, 2007 Share Posted August 26, 2007 Do i have to put premium in if i buy a LGT or can i get away with regular? Will regular cause engine damage or just not put out as many horses? Thanks guys im no pro but... i dont get it sometimes...turbo owners find ways to reduce power, non turbo owners find ways to increase power. why not just trade? Link to comment Share on other sites More sharing options...
The B4 Posted August 26, 2007 Share Posted August 26, 2007 Do i have to put premium in if i buy a LGT or can i get away with regular? Will regular cause engine damage or just not put out as many horses? Thanks guys Premium is $.20 more a gallon. If you drained your tank bone dry and filled it up it would cost $3.71 more a fill up than if you used regular. If you can't afford less than $4 a fill up... you need to be in a 2.5i [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
pengwin Posted August 26, 2007 Author Share Posted August 26, 2007 yeah i understand it doesnt cost much more but i still would like to know if it has any ill effects besides the fact the engine wont make more power Link to comment Share on other sites More sharing options...
red beast Posted August 26, 2007 Share Posted August 26, 2007 premium is reqiured for turbos in an emergency you came use a lower grade but not for daily driving Link to comment Share on other sites More sharing options...
Brady Posted August 26, 2007 Share Posted August 26, 2007 And to add to what Red Beast said, be mindful that if you do end up putting lower grade gas in your car, you have to be careful not to accelerate hard. You also need to be careful about accelerating in 4th and 5th gear in general. Have to drive very easily. There ARE risks of knocking when running a lower grade, so it really isn't worth the chance unless you're in a pinch. Link to comment Share on other sites More sharing options...
pengwin Posted August 26, 2007 Author Share Posted August 26, 2007 Alright, just wanted to know since i was thinking about buying a used LGT and wanted to know just incase the previous driver was an idiot thanks Link to comment Share on other sites More sharing options...
sexylegacy Posted August 26, 2007 Share Posted August 26, 2007 Just as a general rule, any turbo charged or supercharged car, or any engine with over 10:1 compression while non-turbo'd/supercharged, will be required to run on Premium. Link to comment Share on other sites More sharing options...
Canon20D Posted August 26, 2007 Share Posted August 26, 2007 I noticed at least 3 dealers that use Reg. in all their cars Poor brand new engines being subjected to that. And of course the dealers tell you "Test out that power" My car was Full of gas when I picked it up All regular grade As soon as i put 93 in it, it drove soo much better hope nothing happened happened to it with the reg. Plugs were all fouled up but other than that i think its fine Link to comment Share on other sites More sharing options...
Fonzarelli Posted August 26, 2007 Share Posted August 26, 2007 ^^"Plugs were all fouled up but other than that i think its fine" I bought my '06 used with 11k on the odo, you say that if the previous owner used regular, the plugs might be fouled? Link to comment Share on other sites More sharing options...
Canon20D Posted August 27, 2007 Share Posted August 27, 2007 http://legacygt.com/forums/showpost.php?p=1303105&postcount=41 Link to comment Share on other sites More sharing options...
sooberoo Posted August 27, 2007 Share Posted August 27, 2007 The ECU will retard the timing as best it can to compensate for the lower octane fuel. Prolonged use of lower octane fuel or driving hard on the same low octane fuel results in predetonation (which is pinging). Keep it up and you can burn out your engine. Not a good thing! Link to comment Share on other sites More sharing options...
Canon20D Posted August 27, 2007 Share Posted August 27, 2007 ^ and the retarded timing will net you lower MPG which in effect will cost you more. *Just dont do it!* Link to comment Share on other sites More sharing options...
Vimy101 Posted August 27, 2007 Share Posted August 27, 2007 In addition to retarding the timing the ECU will also make the car run rich as well. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted August 27, 2007 Share Posted August 27, 2007 In addition to retarding the timing the ECU will also make the car run rich as well. Only on a Spec B though...... Link to comment Share on other sites More sharing options...
Vimy101 Posted August 27, 2007 Share Posted August 27, 2007 No. On the LGT as well. And Nissans and Hondas and Toyotas and ...... Running rich lowers cylinder temperature. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted August 27, 2007 Share Posted August 27, 2007 No. On the LGT as well. And Nissans and Hondas and Toyotas and ...... Running rich lowers cylinder temperature. Link to comment Share on other sites More sharing options...
Canon20D Posted August 27, 2007 Share Posted August 27, 2007 Moar gass = more quelching = lower temps = less possibilty of detonation but also equals less MPG Link to comment Share on other sites More sharing options...
Vimy101 Posted August 27, 2007 Share Posted August 27, 2007 rly Link to comment Share on other sites More sharing options...
NSFW Posted August 28, 2007 Share Posted August 28, 2007 http://www.orlyowl.com/upload/files/yarly.jpg Link to comment Share on other sites More sharing options...
Guest Gitster Posted August 28, 2007 Share Posted August 28, 2007 YARLY Owl always has last word. You. Link to comment Share on other sites More sharing options...
underscore Posted August 28, 2007 Share Posted August 28, 2007 http://i157.photobucket.com/albums/t80/GonnaHurtSomebody/nowai.jpg Link to comment Share on other sites More sharing options...
coxx Posted August 28, 2007 Share Posted August 28, 2007 I filled up from empty with 89 octane on a road trip last month by accident. I just kept it out of boost till I used it up. It didn't cause any damage but I wouldn't do it on purpose or on a regular basis. "Barack Obama, mothaf#%@a! Barack Obama! I'm the president...of hittin' the ass!" -this is not a political view it's merely a quote from a hilarious tv show. Link to comment Share on other sites More sharing options...
psi365 Posted August 28, 2007 Share Posted August 28, 2007 I've heard the debate many times in many different forums. I've also gotten into this discussion at the Audi training center whne the instructor told us a story. He had to take a at the time new RS6 to ST. Louis for RS6 triaining. On the way down there he decided to do a little experiment and put 87 in it. No major ill effects happened other then his mpg went down, and almost no real performance difference. Don't get me wrong, if the car isn't really advanced (variable valve timing) and such the computer can adjust itself usually enough to cover the fact of the garbage gas you put in. I still do put in 93 just because it improves my fuel mileage and if or when I nedd max performance its still there and I don't have to worry about causing engine damage due to poor fuel. What a lot of people are also forgeting is where you get your gas can make a difference too. If you get some off name brand gas you'll be getting a mixture of a lot of different brand gases and some may not even be the same grade. Some where there is a list of gas manufacturers in which they list the ones that are considered tier one (being the best). I know Shell is a tier one gas. Link to comment Share on other sites More sharing options...
Richard B. Posted August 28, 2007 Share Posted August 28, 2007 Shell is a tier one gas. a shell station here in Mukilteo used to stall my old protege 5. the other gas stations were fine. i had a chevron up in south center close the gaps on my plugs on a different car. they were brand new. in the turbo the butt dyno can tell a difference. i stick to the chevron here in mukilteo. i'm sure i can feel a bottle of fuel system cleaner. some gas just doesnt have that "snap" is all i can think of on how to explain it. Link to comment Share on other sites More sharing options...
