Zed 2.0 Posted October 10, 2007 Share Posted October 10, 2007 whats the best place to buy the jdm rsb? The only places I've found that have it are Rallitek and AVO. Rallitek lists them as in stock, but after you buy it you'll find out there is a 2-3 week delay. AVO has it for $50 more than Rallitek. Not sure if they have it in stock. Link to comment Share on other sites More sharing options...
Guest Posted October 10, 2007 Share Posted October 10, 2007 rallitek or avo Link to comment Share on other sites More sharing options...
mikeyan Posted October 10, 2007 Share Posted October 10, 2007 i like my new perrin 25mm rear .... it hits my custom catback though, so i have to do some clearance work Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
chenc544 Posted October 10, 2007 Share Posted October 10, 2007 The only places I've found that have it are Rallitek and AVO. Rallitek lists them as in stock, but after you buy it you'll find out there is a 2-3 week delay. AVO has it for $50 more than Rallitek. Not sure if they have it in stock. Rallitek just got some JDM bars in, so they should be in stock over there. My bar was shipped yesterday. Not sure what the price is now but the bar was $100 when I ordered it. Link to comment Share on other sites More sharing options...
LRegvall Posted October 10, 2007 Share Posted October 10, 2007 i like my new perrin 25mm rear .... it hits my custom catback though, so i have to do some clearance work Mike What kind of FSB are you using with the 25mm RSB? What about springs/shocks? Link to comment Share on other sites More sharing options...
suds2250 Posted October 11, 2007 Share Posted October 11, 2007 Another happy whiteline user. +1 on getting the rear reinforcement brakets. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
bgLGT Posted October 11, 2007 Share Posted October 11, 2007 I have the AVO rear bar only. It's really well balanced with the front bar. I have no plans on going to stiffer coil-over springs so I wanted to make sure that the bar I ran wasn't going to overpower my springs (cause tire lift). It's very neutral. Link to comment Share on other sites More sharing options...
silverfool Posted October 11, 2007 Share Posted October 11, 2007 i wonder if i'd be happier just getting the roll center adjuster rather than new sway bars. my new springs have removed the lift/dive but the turns still have the car leaning more than i like. Link to comment Share on other sites More sharing options...
LRegvall Posted October 11, 2007 Share Posted October 11, 2007 What's a roll center adjuster? You can lower the roll center with shorter springs but the roll balance to me is just off on the car. Way too much front stiffness and way too little rear stiffness. I prefer more neutral roll balance. A lower roll center should reduce the impact of the roll imbalance but it would still be imbalanced. Link to comment Share on other sites More sharing options...
mikeyan Posted October 11, 2007 Share Posted October 11, 2007 What kind of FSB are you using with the 25mm RSB? What about springs/shocks? Cusco 23mm front. I had the cusco 21mm rear, but the perrin is in there now. Bilsteins + STI pinks for now, KW Variant 2s soon. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
sactojesse Posted October 11, 2007 Share Posted October 11, 2007 I'm running the stock USDM/JDM 21 mm FSB and the JDM hollow 20 mm RSB with AVO reinforcement brackets on my LGT wagon. It has Bilstein HDs w/ JDM LGT wagon springs. Link to comment Share on other sites More sharing options...
LRegvall Posted October 11, 2007 Share Posted October 11, 2007 Cusco 23mm front. I had the cusco 21mm rear, but the perrin is in there now. Bilsteins + STI pinks for now, KW Variant 2s soon. Mike So your rear bar is thicker than your front bar? Sounds interesting. How's the handling balance with that combo? Neutral, oversteer, etc? What are KW Variant 2s? Link to comment Share on other sites More sharing options...
xenon expert Posted October 11, 2007 Share Posted October 11, 2007 What are KW Variant 2s? coilovers. Link to comment Share on other sites More sharing options...
mikeyan Posted October 12, 2007 Share Posted October 12, 2007 So your rear bar is thicker than your front bar? Sounds interesting. How's the handling balance with that combo? Neutral, oversteer, etc? What are KW Variant 2s? Fairly neutral, but I have the rear bar on the softer of the two settings... gonna try the stiffer setting this weekend. Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
LRegvall Posted October 12, 2007 Share Posted October 12, 2007 Fairly neutral, but I have the rear bar on the softer of the two settings... gonna try the stiffer setting this weekend. Mike None of the oversteer that some worry about. My experience with 21mm stock FSB and 20mm AVO RSB (with stock springs/shocks/ride height) is also very neutral. Link to comment Share on other sites More sharing options...
mikeyan Posted October 12, 2007 Share Posted October 12, 2007 yeah, no oversteer... if you're in the LA area, you're more than welcome to come for a ride in it if you're curious.... Mike SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted October 12, 2007 Share Posted October 12, 2007 three little letters. A V O Link to comment Share on other sites More sharing options...
Infamous1 Posted October 12, 2007 Share Posted October 12, 2007 None of the oversteer that some worry about. My experience with 21mm stock FSB and 20mm AVO RSB (with stock springs/shocks/ride height) is also very neutral. Oem FSB is 20mm. Link to comment Share on other sites More sharing options...
Infamous1 Posted October 12, 2007 Share Posted October 12, 2007 I run Whitelines 21mm F & R sways w/GP Moto coilovers, very neutral with great reduction in turn in. Link to comment Share on other sites More sharing options...
sactojesse Posted October 12, 2007 Share Posted October 12, 2007 Oem FSB is 20mm. I've always heard that the stock FSB is 21mm solid. I've never personally measured mine though. Link to comment Share on other sites More sharing options...
Infamous1 Posted October 12, 2007 Share Posted October 12, 2007 ^^^ Thats strange where you hear that? I have never heard 21mm, well anyways it stamped right on the bushings for the stock FSB "20mm". Link to comment Share on other sites More sharing options...
sactojesse Posted October 12, 2007 Share Posted October 12, 2007 ^^^ Thats strange where you hear that? I have never heard 21mm, well anyways it stamped right on the bushings for the stock FSB "20mm". From Rallitek's website description of the AVO RSB: The AVO designed 20mm solid rear stabilizer bar is a big improvement over the standard USDM or JDM OEM tube-construction rear stabilizer bar. Adjustable for roll resistance, it improves turn-in, removes body roll in corners, and works very well with the standard 21mm front stabilizer bar. A must have! Will fit to a USDM Legacy GT or Outback XT with the provided rear 20mm polyurethane bushings. Add AVO Endlinks for a complete kit! Source: http://rallitek.com/avo20restbar.html Link to comment Share on other sites More sharing options...
Infamous1 Posted October 13, 2007 Share Posted October 13, 2007 Well their wrong, just get under and check the bushings for yourself. Wouldn't be the first time a JDM comany was wrong about a USDM part, even though the bars are the same for both vehicles. I've never heard that they were 21mm... Link to comment Share on other sites More sharing options...
LRegvall Posted October 13, 2007 Share Posted October 13, 2007 I reached under with the calipers and the 21mm went on snugly and the 20mm didn't go on. I'll check more precisely over the weekend and look at the bushings. Odd that the bar would be 21mm (though that's what I've read pretty much everywhere) with bushings labeled 20mm. Link to comment Share on other sites More sharing options...
LRegvall Posted October 15, 2007 Share Posted October 15, 2007 This made me curious. I got under the car and calipered the stock FSB and AVO RSB. The front measures 21mm and the rear 20mm. The front bushing does have a "20" on it but it must refer to something else, or maybe it's another metric system. Link to comment Share on other sites More sharing options...
