wongmic75 Posted July 28, 2007 Share Posted July 28, 2007 Dear Gang, I thought I would be adventurous and change my oil for the first time for my 06 SE wagon...tried to follow all the instructions on the L7 .com, everything was working well, except the suby tech must have used a three hundred pound gorilla to tighten the filter on... I have a filter that I had purchased for my 03 GT wagon... and it should be the same for my 06---Part #15208AA100 I took it to my local auto store, bought a wrench cap that fit perfect, but is seems like the filter installed on my 06 is smaller as the wrench slips when I try to torque it loose... I have now tried 3 other types of wrenches... all to no effect... Please help? Does Subaru have an OEM wrench that I can buy? THanks ahead of time... Michael Link to comment Share on other sites More sharing options...
qikslvr Posted July 28, 2007 Share Posted July 28, 2007 Put an oil pan under it and pound a flat head screwdriver into one side and out the other near the bottom of the filter and twist. Let's kick this pig! Link to comment Share on other sites More sharing options...
BigBad Posted July 29, 2007 Share Posted July 29, 2007 I have several oil filter wrenches from previous cars. One of my older ring style filter wrenchs does fit the OEM filter and I can remove it with that. The handle of this one tilts downward so you can get it in tight places. I am sure Subaru does sell a specific tool for this filter. Link to comment Share on other sites More sharing options...
meier motor sports Posted July 29, 2007 Share Posted July 29, 2007 a band wrench works great. screw drive tip mentiond works well. or use the pliers type and grip the shit outa it. you know pliers work better in one direction then the other right? Link to comment Share on other sites More sharing options...
c-lo Posted July 29, 2007 Share Posted July 29, 2007 +1 for the band wrench. helped me out big time 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
kenchan Posted July 29, 2007 Share Posted July 29, 2007 i remember my sear's oil filter wrench worked fine. although i like my modded griot's oil filter wrench. :grin: works even better. Link to comment Share on other sites More sharing options...
