prelude Posted November 24, 2004 Share Posted November 24, 2004 I think many LGT owners have this problem, the creeks and crackling from the dashboard. It is getting more and more obvious on my car. Today I found out the rattle is from driver side, between A pillar, windshield and dashboard. I also notice that when I push the dashboard, that rattling sound goes away. So I put something in between the A pillar, windshield and dashboard,( some folded paper). Amazingly, the noise is GONE!! Link to comment Share on other sites More sharing options...
Enlight Posted November 24, 2004 Share Posted November 24, 2004 I also get buzzing from my passenger side door panel sometimes when bass is present. muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
axis008 Posted November 24, 2004 Share Posted November 24, 2004 Moving to the warranty section. Could you talk about where you put that paper so others can try it? Is it visible? -ben Link to comment Share on other sites More sharing options...
Deer Killer Posted November 24, 2004 Share Posted November 24, 2004 I have the _exact_ same problem.. I think it's the A-pillar cover where it meets the dash... I tried taking the cover off and it wasn't going so well so I gave up and saved it for later. I think you have to literally bend it in the middle to pull it of the top tab.. I'll let somebody else do it first :) Link to comment Share on other sites More sharing options...
frontrangeSubie Posted November 24, 2004 Share Posted November 24, 2004 I think Sube555 had Subaru move a "relay" that was rubbing against the a-pillar. Im taking mine in next week....I have a buzz somewhere near where you guys are talking about (Drivers side a-pillar/windshield area). It only happens when decelerating and accelerating under load. Link to comment Share on other sites More sharing options...
B4_Maniac Posted November 24, 2004 Share Posted November 24, 2004 I took mine in today, and they said they couldn't hear anything. It has been irritateing me for some time. But, then again, I am glad they didn't blame it on my coilovers, cuz they easily could have and brushed me off. I am glad I have this thread so I can print it out and show them I am not the only one. B4 Link to comment Share on other sites More sharing options...
prelude Posted November 24, 2004 Author Share Posted November 24, 2004 took pictures today, just "insert" something in between these "gaps". It works for me! Link to comment Share on other sites More sharing options...
Deer Killer Posted November 25, 2004 Share Posted November 25, 2004 Fixed it, properly. To take the A-pillar cover off, pry the top away from the A-pillar, use a flat screwdriver to press the shiny metal release tab inside, and then just pull it off. Some sticky foam (vinyl weather stripping is my choice) on both sides where it meets the dash, and all quiet now. Link to comment Share on other sites More sharing options...
ih8vtec13 Posted November 25, 2004 Share Posted November 25, 2004 I have it too it usualy happens at arroun 3k to 4k rpms and i guess its there becauese thats the range of max torque if I'm not mistaken. I will let my dealer work it out when i go in for service at 6k. Link to comment Share on other sites More sharing options...
eurospec Posted December 24, 2004 Share Posted December 24, 2004 Subaru is not the only automobile to feature the non-stop in-car compilation of annoying sounds. My mom's 2003 Nissan Maxima SE was warrantied for the Bose 6 disc radio unit. The problem was it did not eject discs nor did it play them. After getting the new unit installed and a month of use, annoying squeaks and rattles started to come from the unit and the air vents that were located on top of it. After going twice to the dealer with this problem, it was never fixed. The noice was stop when you pressed down on the plastic trim around the vents beneath the radio. The solution for us was simple. When I inserted a credit card between the radio and the vent trim, the noice stopped. After looking hard for an 'aftermarket' part, I inserted a small piece of rubberish plastic between the trim and noice was gone. So much for the dealer's measly effort and help. Link to comment Share on other sites More sharing options...
Rexmobbin Posted December 26, 2004 Share Posted December 26, 2004 Prelude, nice shots. i too have this rattle, but mine comes from the area behind the radio, like INSIDE the dash somewhere. i usually only hear it when i'm driving over a surface that's not perfectly smooth. a creaking sound. very annoying. i usually just keep the radio on "loud" mode. :D Link to comment Share on other sites More sharing options...
Deer Killer Posted December 26, 2004 Share Posted December 26, 2004 [QUOTE=Rexmobbin']Prelude, nice shots. i too have this rattle, but mine comes from the area behind the radio, like INSIDE the dash somewhere. i usually only hear it when i'm driving over a surface that's not perfectly smooth. a creaking sound. very annoying. i usually just keep the radio on "loud" mode. :D[/QUOTE] I know where it is.. It's where the rear of the top of the radio faceplate meets the dash material.. Almost sounds like someone left loose change behind there. The only problem is it's hard to fix it without having the material you use show through.. I'm thinking it would be better to use a dremel and cut off all the little "fins" that make contact.. Useless anyway. Link to comment Share on other sites More sharing options...
B4_Maniac Posted December 27, 2004 Share Posted December 27, 2004 Mine is in the shop as we speak for the rattle. The mechanic said the fuel lines are rubbing together when they expand and contract do to the changes in the tempreture. I hope thats the issue. Link to comment Share on other sites More sharing options...
frontrangeSubie Posted January 3, 2005 Share Posted January 3, 2005 [quote name='B4_Maniac']Mine is in the shop as we speak for the rattle. The mechanic said the fuel lines are rubbing together when they expand and contract do to the changes in the tempreture. I hope thats the issue.[/QUOTE] The Legacys have a fuel line rubbing problem that causes a buzz/rattle behind the drivers dash (actually it is in the engine bay at the firewall) Yes.....it is your fuel lines rubbing...here is my thread about the fix: [url]http://legacygt.com/forums/showthread.php?t=5684[/url] Link to comment Share on other sites More sharing options...
GTLegs Posted January 3, 2005 Share Posted January 3, 2005 man i feel like a dummy now, i had a rattle in this location too, its been there since the day i bought my car, ive taken the a-pillar out several times to put foam, cushioned tape, and even sound deadener all to no prevail, well yesterday my garage door opener quit working so i took it off the visor and put it in the console by my wallet so i would remember to get a new battery for it, and voalla the sound is gone!!!, isnt it funny how goofy we humans are? Link to comment Share on other sites More sharing options...
