gianspi Posted June 18, 2007 Share Posted June 18, 2007 Hello, Does anyone know what type of glue I can use to re-apply one of the OEM badges? After debadging them, most of the glue was lost. Thanks! rebadge, re-badge enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
Rommel Posted June 18, 2007 Share Posted June 18, 2007 it uses foam tape Link to comment Share on other sites More sharing options...
gianspi Posted June 18, 2007 Author Share Posted June 18, 2007 Thank you! enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
gianspi Posted June 18, 2007 Author Share Posted June 18, 2007 http://solutions.3m.com/wps/portal/3M/en_US/Automotive/OEM/Solutions/Exterior/Nameplate/ enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
gianspi Posted July 1, 2007 Author Share Posted July 1, 2007 I had to buy a 30' roll, so if anyone needs some of this, I will be happy to send you some at no charge. Just PM me. enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
sexylegacy Posted July 1, 2007 Share Posted July 1, 2007 wish someone had a Liberty badge...... Link to comment Share on other sites More sharing options...
PhilT Posted July 1, 2007 Share Posted July 1, 2007 I used clear silicone to put the lettering back on, worked fine. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
gianspi Posted July 1, 2007 Author Share Posted July 1, 2007 How do you use that tape on the lettering? Do you have to cut it out around each letter? I'm guessing so. My car is in the bodyshop ATM so I haven't been able to rebadge. After I got the tape my car was keyed enough zip ties and duct tape will fix anything. Link to comment Share on other sites More sharing options...
Gire Posted July 1, 2007 Share Posted July 1, 2007 I used clear silicone to put the lettering back on, worked fine. That sounds kinda permanent eh? I'd do that to flirt with the idea of putting 'GT' back on the car but I'd rather use something that could be removed as easily as the OEM stuff in hot weather... Link to comment Share on other sites More sharing options...
PhilT Posted July 1, 2007 Share Posted July 1, 2007 That sounds kinda permanent eh? I'd do that to flirt with the idea of putting 'GT' back on the car but I'd rather use something that could be removed as easily as the OEM stuff in hot weather... The silicone peels off easily, just like bathroom sealant, well, it is bathroom sealant Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
6thGear Posted July 3, 2007 Share Posted July 3, 2007 I've used (Automotive) Goop for badges and trim on several cars over the years. It's easy to work with. Any excess or splash can be rubbed away. Just make sure the application is thorough and not done when it's about 80° or so, or freezing. "Make your car work better or go faster. Do that, or it's Bling. Bling is not fast. Bling is added weight. So Bling is Sh!t." - Tom Hnatiw, Car Guy Link to comment Share on other sites More sharing options...
