Legacy2.5R Posted May 27, 2007 Share Posted May 27, 2007 In 10,000 miles my powertrain warrenty is up, and im thinking od swapping out my 4EAT for a 5MT. i have located the transmission itself with only 6000 miles on it for only 500$, so i think i will probably pick that up and then start buying all the parts that i need. my question is however, is the rear differential in the MT cars different from the AT cars? the 4EATs torque split is 90/10, the MT is 50/50. i was wondering if i would need the an MT rear end to handle the difference. any thoughts? Link to comment Share on other sites More sharing options...
rao Posted May 27, 2007 Share Posted May 27, 2007 The rear diff is different in auto transmission cars, both physically and the gearing. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Legacy2.5R Posted May 27, 2007 Author Share Posted May 27, 2007 thats what i thought, thanks rao. looks like its junkyard sifting now. Link to comment Share on other sites More sharing options...
ebpda9 Posted May 28, 2007 Share Posted May 28, 2007 if you manage to get the GT 5MT the gearing of the rear differential is the same 4.11 Link to comment Share on other sites More sharing options...
TPLGT Posted May 28, 2007 Share Posted May 28, 2007 I have friend who loves trannys..... Rehab is for quitters. Link to comment Share on other sites More sharing options...
ebpda9 Posted May 28, 2007 Share Posted May 28, 2007 ^thanks for sharing Link to comment Share on other sites More sharing options...
tougefox Posted May 28, 2007 Share Posted May 28, 2007 pointless, just send your tranny computer out to get it tuned for firmer shifts. The swap to me doesnt seem worth it. If it were a direct swap that would be a diff story. Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 28, 2007 Share Posted May 28, 2007 Woof. Good luck....It is dooable. But mosy people swap for an STi 6 speed. Link to comment Share on other sites More sharing options...
SLegacy99 Posted May 28, 2007 Share Posted May 28, 2007 http://66.49.172.173/subaru/ This guy went from 4EAT to 5MT. Link to comment Share on other sites More sharing options...
Legacy2.5R Posted May 29, 2007 Author Share Posted May 29, 2007 i hear the STI6MT dosent mount up right.. can someone confirm this? Link to comment Share on other sites More sharing options...
Zanatech Posted May 29, 2007 Share Posted May 29, 2007 i am pretty sure the trannys mount up correctly but you do need the rear diff and half shafts/axles, etc... i heard that the subaru motors and drive trains were like lego blocks, you can just switch one thing out for another etc... and build on it. Link to comment Share on other sites More sharing options...
Hanger Posted May 29, 2007 Share Posted May 29, 2007 Hmmm... i have a friend who drives a AT bugeye, and he's interested in getting our 4EAT with sport shift tranny.. maybe if he buys mine and i can swap to 5MT too? ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
zildjiank Posted May 30, 2007 Share Posted May 30, 2007 i hear the STI6MT dosent mount up right.. can someone confirm this? Yeah, bad idea. You would need to CUSTOM make it to fit, just buying the "right parts" and rear end and axles and all that does NOT add up. It is confirmed, a couple of people here on this site have tried it a ways back, but it requires such custom work that it is better to not go w/ the STI 6 speed. If I were you and really wanted a 6 speed, go w/ the 07 spec B tranny and rear ends and all. Though that will cost a bunch. IMO 5MT is your best bet plus the rear end... Link to comment Share on other sites More sharing options...
tougefox Posted May 30, 2007 Share Posted May 30, 2007 Yeah, bad idea. You would need to CUSTOM make it to fit, just buying the "right parts" and rear end and axles and all that does NOT add up. It is confirmed, a couple of people here on this site have tried it a ways back, but it requires such custom work that it is better to not go w/ the STI 6 speed. If I were you and really wanted a 6 speed, go w/ the 07 spec B tranny and rear ends and all. Though that will cost a bunch. IMO 5MT is your best bet plus the rear end... so are you saying the 5mt bolts right in as long as u use the whole rear end or just rear diff? What bout clutch pedals, master cylinder and all that smish smash Link to comment Share on other sites More sharing options...
zildjiank Posted May 30, 2007 Share Posted May 30, 2007 I am not the expert on these things, but I do know for a fact that the STI 6spd does not fit w/o major custom work. The axles I am not sure about, but I would venture to guess that it probably would need the whole shabang, diff and axles from the 5MT Leggy...but that is just a guess. Clutch pedal is an obvious have to that doesn't look like a just "bolt on." Master cylinder? Why would you need to worry about that? The brake system has nothing to with tranny AFAIK... Link to comment Share on other sites More sharing options...
ebpda9 Posted May 30, 2007 Share Posted May 30, 2007 my car has the spot for the clutch pedal, so the clutch pedal would be basically a bolt on. Also there is room and brackets for the clutch master cylinder Link to comment Share on other sites More sharing options...
tougefox Posted May 30, 2007 Share Posted May 30, 2007 eh still doesnt seem worth it to me. To each their own. Link to comment Share on other sites More sharing options...
zildjiank Posted May 31, 2007 Share Posted May 31, 2007 clutch master cylinder Oh yes, forgot about that one. Link to comment Share on other sites More sharing options...
