rockhead Posted March 14, 2007 Share Posted March 14, 2007 I guess the car was running too good for me. I took advantage of the warm weather yesterday and sprayed some degreaser on and under the engine, then hit it with my powerwasher. It started right back up, but now stutters and pops under load. It idles OK and revs with a little miss, but hardly takes throttle in drive. I tried driving down the block and the engine light came on, steady at first, then it began flashing! This morning the engine seems to run a little better, but the light is still on. What have I done? Link to comment Share on other sites More sharing options...
wukindada Posted March 14, 2007 Share Posted March 14, 2007 Simple green & just the pressure from the hose is more than adequate. Rinse......never soak!! I'd suggest opening the hood & running a fan over the engine for several hours. Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
BDII Posted March 14, 2007 Share Posted March 14, 2007 S0aP iN yOuR IntErCoOlEr!!! oh noes!!!! Open your air box, make sure there is no water on or around the MAF or filter Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
rabydanimal Posted March 14, 2007 Share Posted March 14, 2007 I've been told to always leave the engine running if you plan on spraying it down with some sort of engine cleaner. Link to comment Share on other sites More sharing options...
wukindada Posted March 14, 2007 Share Posted March 14, 2007 This is dirty for me....... http://legacygt.com/forums/attachment.php?attachmentid=32186&d=1171549130 Formula above & then after drying apply CD2 engine detailer. You should always have a few old toothbrushes handy & quite a few old microfiber rags Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
rockhead Posted March 14, 2007 Author Share Posted March 14, 2007 I can't beleive that with distributorless ignitions this kind of nonsense can still happen! I'm off today and going out to pull the plug wires and dry everything out. Hopefully my local Advance will have a code reader and I can figure this out. I really don't feel like swapping out sensors for a week. Link to comment Share on other sites More sharing options...
rockhead Posted March 14, 2007 Author Share Posted March 14, 2007 OK, here's what I found. I stuck my head under the hood with the engine running and saw something unusual; steam coming from one of the spark plug wire boots. I shut it down and pulled the plug wires. Would you beleive two of the four spark plug recesses were half-filled with water? I stuffed a rag in them, sprayed some electrical contact cleaner in, then dried with compressed air. I gave the plug boots a spray, too. Buttoned her all up and went for a ride. Seems like everything is back to normal, but the engine light is still on. Hopefully it will reset after a while. I might try to get it reset later today. I'm going to stick to pressurewashing my deck and patio from now on. Link to comment Share on other sites More sharing options...
rabydanimal Posted March 14, 2007 Share Posted March 14, 2007 I don't believe CELs reset themselves? Correct me if I'm wrong but I think you'll have to clear it either by disconnecting the battery or I believe Autozone will rent a device for you to clear it. Or, if you know anyone with an AP, they can do it for you. Link to comment Share on other sites More sharing options...
robinlsb Posted March 14, 2007 Share Posted March 14, 2007 NEVER, NEVER, NEVER use a power washer on a modern motor. PERIOD!!!!!!! "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Bdubs Posted March 14, 2007 Share Posted March 14, 2007 Unplug the battery for a couple hours, the ECU should reset, and the light should be off now since you fixed the problem. Link to comment Share on other sites More sharing options...
rockhead Posted March 14, 2007 Author Share Posted March 14, 2007 WOOOOOOOHOOOOOOOO! Went to my local Advance Auto Parts and took advantage of their free diagnostic tool service. Of course, the counter kid mentioned that it's "illegal" to reset the light, although he "thinks" the tool will do it. It threw three codes: Misfire Cylinder #1, Misfire Cylinder #3, Misfire Cylinder #4. I cleared them all and the light is out. While there I bought a neat little refrigerant recharge kit with a built-in pressure guage. I connected it to my DOA A/C and charged it up. The compressor came on the the A/C started working! You gotta love it when things start coming together.... Link to comment Share on other sites More sharing options...
Kraziken Posted March 14, 2007 Share Posted March 14, 2007 Here's a good web article on how to detail your engine. I myself, killed my backup battery siren when cleaning my engine bay. That sucker gets wrapped in plastic now. http://autopia.org/forum/guide-detailing/80226-engine-cleaning-detailing.html Link to comment Share on other sites More sharing options...
ZinFreak Posted March 14, 2007 Share Posted March 14, 2007 Powerwasher on the engine. Wow Degreaser and a hose turned on gentle with no nozzle is all that it takes. That and a roll of shop towels a bit of elbow grease. -Zin 06 LGT LTD GRP 5MT 07 FXT LTD OBP 4EAT Link to comment Share on other sites More sharing options...
