JK_Asian Posted March 6, 2007 Share Posted March 6, 2007 So I was working on my audio yesterday. Everything was fine before that. Somehow I shorted some wire on the harness and now the Interior lights and the Head unit won't work. Also the keyless entry died too, and the security light stopped blinking. Does anyone knows what went wrong? Link to comment Share on other sites More sharing options...
bmorrisj Posted March 6, 2007 Share Posted March 6, 2007 fuse? Link to comment Share on other sites More sharing options...
JK_Asian Posted March 6, 2007 Author Share Posted March 6, 2007 fuse? I checked every fuse in the cabin and the engine compartment. none of them seems broken. Also I don't think that the interior lights, radio, and keyless alarm system works on the same fuse? Link to comment Share on other sites More sharing options...
Seth1784 Posted March 7, 2007 Share Posted March 7, 2007 hmmm only thing i can think it would or even should be is a fuse.... its possible it would have popped more then one. if you look in the manual it will tell you what fuse goes to what. that could help you narrow things down... ummm other then that only thing i can say is have subaru run a diagnostics thing on it to see if something in the computer went bad, i wouldnt tell them what happened though just incase that way you can get the work done for nothing. Link to comment Share on other sites More sharing options...
kacarnes Posted May 5, 2007 Share Posted May 5, 2007 Did you ever find a solution to this problem? I'm having the same issue and trying to trace wires back through the dash for three straight days is killing me. Link to comment Share on other sites More sharing options...
butrball12 Posted July 8, 2007 Share Posted July 8, 2007 same issues here.... any help??? Link to comment Share on other sites More sharing options...
SpecBee Posted July 10, 2007 Share Posted July 10, 2007 You could have lost a common ground connection. Or a bonding ground. Run a wire from your battery neg terminal and connect a test light or meter to the wire then check your components that are not working. If you are not getting 12vdc then you have a blown fuse or fuseable link. Check all fuses with your meter. Set it to DC and read across both sides. If you get 0vdc then the fuse is good. If you get 12vdc then it is blown. If you smoked any wires then you could have taken out the main control board. Link to comment Share on other sites More sharing options...
Ninjabem Posted July 13, 2007 Share Posted July 13, 2007 any solution to this problem? or the cause of it? the same damn thing just happened to me earlier today and it's really upsetting everything i've setup so far Link to comment Share on other sites More sharing options...
msmith Posted July 13, 2007 Share Posted July 13, 2007 For your sake I hope you didn't damage the "Body Integrated Unit" as Subaru calls it... aka Body Control Module or Computer Module Link to comment Share on other sites More sharing options...
Ninjabem Posted July 14, 2007 Share Posted July 14, 2007 I figured out what it was today. It was a 15A fuse located in the main fuse box (well for my 99' legacy) for the interior lighting. Quick fix and everything works perfect now. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 14, 2007 Share Posted July 14, 2007 yay for frying fusible links My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
