mccorry Posted March 19, 2007 Share Posted March 19, 2007 Passenger front is #1 cylinder. I'd guess a rod bearing, wrist pin issue, or piston issue. Link to comment Share on other sites More sharing options...
Visionhu Posted March 19, 2007 Author Share Posted March 19, 2007 That's my luck...we'll see. Thanks guys! Link to comment Share on other sites More sharing options...
mccorry Posted March 19, 2007 Share Posted March 19, 2007 Best wishes... let us know, dude! Link to comment Share on other sites More sharing options...
dr_sharp Posted October 14, 2007 Share Posted October 14, 2007 What was the verdict? lol Link to comment Share on other sites More sharing options...
Visionhu Posted October 15, 2007 Author Share Posted October 15, 2007 What was the verdict? Finally we found the problem. Removed the valve cover and had a look at the camshafts. One of the camshafts' fastening screw came a bit loose - actually there are two U-shaped metal parts that hold the camshaft to its place with two screws in each, if I remember correctly. So the only thing we had to do is to fasten the screws again, and that solved the noise problem. The only thing I can not understand, is how could the screw come loose? We did not see any signs that the engine had been ever disassembled before Link to comment Share on other sites More sharing options...
dr_sharp Posted October 15, 2007 Share Posted October 15, 2007 Wow... close call. I thought for sure you were going to need a rebuild based on the description and noise. Good to know, thanks. lol Link to comment Share on other sites More sharing options...
