jnd121 Posted February 25, 2007 Share Posted February 25, 2007 I recently changed my air filter with another OEM one and afterwards my gas mileage seemed to noticeably decrease ~2-3 mpg). Any reason why this may be? Should I have disconnected the negative terminal from the battery to reset the ECU? I wouldn't think I would have to since I replaced it with the same filter. Link to comment Share on other sites More sharing options...
SLegacy99 Posted February 25, 2007 Share Posted February 25, 2007 I guess you could try resetting it. Seems odd to me, but if your old one was really dirty could have an impact on things. Link to comment Share on other sites More sharing options...
TomH Posted February 25, 2007 Share Posted February 25, 2007 I had the same thing happen but after 2 full tanks of gas I'm back up then the 21mpg range and before it was like 19mpg. I didn't unhook the battery either, I just did the filter swap. Link to comment Share on other sites More sharing options...
jnd121 Posted February 25, 2007 Author Share Posted February 25, 2007 Hmmm....maybe I will give it another tank and see what happens. If it is still eating gas, I will disconnect the negative terminal on my battery to reset it. How long do you leave it disconnected for? Link to comment Share on other sites More sharing options...
Underdog Posted February 25, 2007 Share Posted February 25, 2007 Maybe it's your driving? I notice a average difference of >2mpg between tank mileage calculations. If I had just put in a filter I'd be trying to notice the improved response and flow that I bought it for, increasing my fuel consumption (even subconsiously). The Crimson Dynamo Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted February 25, 2007 Share Posted February 25, 2007 ^ to the above. Also, when I got my Blitz drop in filter I noticed my MPG went down because I liked the "woosh" sound a bit much. Seriously though, it's probably the throttle response and it being better than your older filter. Link to comment Share on other sites More sharing options...
Ronin Spec. B Posted November 15, 2007 Share Posted November 15, 2007 ^ to the above. Also, when I got my Blitz drop in filter I noticed my MPG went down because I liked the "woosh" sound a bit much. Seriously though, it's probably the throttle response and it being better than your older filter. Agreed. With the new filter your throttle response has probably improved somewhat. Just ease off the "loud pedal" a bit. Link to comment Share on other sites More sharing options...
Vimy101 Posted November 15, 2007 Share Posted November 15, 2007 Winter gas is also probably responsible for some of the decreased mpg. I notice about a 10% penalty from it in my experience. Link to comment Share on other sites More sharing options...
TehAntiChrist Posted November 15, 2007 Share Posted November 15, 2007 you are also filling up with winter gas now...mileage will decrease some Link to comment Share on other sites More sharing options...
Vimy101 Posted November 15, 2007 Share Posted November 15, 2007 ^ Beat cha! Link to comment Share on other sites More sharing options...
TehAntiChrist Posted November 15, 2007 Share Posted November 15, 2007 ^ Beat cha! must be that Spec B in ya Link to comment Share on other sites More sharing options...
Underdog Posted November 15, 2007 Share Posted November 15, 2007 ^ Beat cha! To a thread that had been dead for 9 months... The Crimson Dynamo Link to comment Share on other sites More sharing options...
Vimy101 Posted November 15, 2007 Share Posted November 15, 2007 Nothing dies on the internets. Link to comment Share on other sites More sharing options...
jp51mustang Posted November 18, 2008 Share Posted November 18, 2008 Glad you guys brought this thead back. I noticed the same drop in mpg after my filter change. I'm only on the first tank of gas since the change so I'll wait and see what happens after two tanks. Thanks Link to comment Share on other sites More sharing options...
ehsnils Posted November 18, 2008 Share Posted November 18, 2008 Winter gas is also probably responsible for some of the decreased mpg. I notice about a 10% penalty from it in my experience. A more important factor is actually the viscosity of the oil in the transmission when the outside temperature drops. Link to comment Share on other sites More sharing options...
Molal24 Posted November 18, 2008 Share Posted November 18, 2008 Yeah mine actually increased in gas mileage once I changed my filter. It's wierd though, my mileage is back down now that it is freezing cold and the winter gas has hit gas stations. Link to comment Share on other sites More sharing options...
