HNRB4LGT Posted February 10, 2007 Share Posted February 10, 2007 man, the greatest flaw of the legacy is truly the laggy e- throttle. Anybody know where to get a different throttle body? Will the ecu let you do that? For the last time, my car is not a Camry Link to comment Share on other sites More sharing options...
Scotty Posted February 10, 2007 Share Posted February 10, 2007 What's wrong with the throttle, mine works fine. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 10, 2007 Share Posted February 10, 2007 You can reprogram it. I believe most off-the-shelf tunes will reprogram it. If you want something different, you can ask your tuner if they'll adjust it to your taste. I copied the STi throttle mapping and used that for a while. It was a little bit too touchy for me. If you are hitting the throttle all the way and get a slight lag, it might actually be the OL/CL delay which you can also zero out. Link to comment Share on other sites More sharing options...
Xenonk Posted February 10, 2007 Share Posted February 10, 2007 you just get it reprogrammed to take out the "luxury" kind of throttle response.. Keefe Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted February 11, 2007 Share Posted February 11, 2007 I don't like it either - I'm glad to see there's a fix for it. Link to comment Share on other sites More sharing options...
Opie Posted February 11, 2007 Share Posted February 11, 2007 What's wrong with the throttle, mine works fine. Mine too. Link to comment Share on other sites More sharing options...
f1anatic Posted February 11, 2007 Share Posted February 11, 2007 What is your issue precisely ? e-throttle or turbo lag ? Both can be taken care of via reprogramming...no need to change anything really. Link to comment Share on other sites More sharing options...
fweasel Posted February 11, 2007 Share Posted February 11, 2007 My wife's stock 05 has no lag associated with the drive by wire throttle. My 06 has a noticeable amount more both in stock, COBB satge 1 and TDC stage 2 trims. I plan on having that issue addressed during my upcoming protune. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
HNRB4LGT Posted February 11, 2007 Author Share Posted February 11, 2007 What is your issue precisely ? e-throttle or turbo lag ? Both can be taken care of via reprogramming...no need to change anything really. nah its not the turbo lag, when ever i mash on the throttle it gives me a bit of a lag. I guess im gonna go to the local tuner to get my throttle mapping changed. For the last time, my car is not a Camry Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted February 11, 2007 Share Posted February 11, 2007 What is your issue precisely ? e-throttle or turbo lag ? Pretty sure it's the E-throttle. I assume turbo lag is the lack of power at low RPMs.. This is a lack of response. My last car was an instant response. Tap the gas, the engine jumps. The LGT doesn't do this when at any steady RPM. Every time you want to go, you have to take into account the 1/4 - 1/2 second for the ECU to realize that you really do want to go. It's annoying, but not a deal breaker. Another example is when going over speed bumps - the LGT doesn't jump at all when you try to keep your foot steady on the gas (and fail)... It's smooth. My last car would jump and studder uncontrollably if I did that because of the minor movements in the gas pedal (I'd push the clutch in to avoid this of course). Link to comment Share on other sites More sharing options...
Scotty Posted February 11, 2007 Share Posted February 11, 2007 Turbo lag is lack of power at low RPM, but it also results in lack of response. Until you get to about 2700-3000 rpm, the 2.5GT will feel unresponsive when compared with other engines like the 2.5i. Link to comment Share on other sites More sharing options...
hogmeat Posted February 11, 2007 Share Posted February 11, 2007 Who here reprograms the E-throttle? Does TDC do it? I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
John M Posted February 11, 2007 Share Posted February 11, 2007 Basically any tune probably includes tweaking the throttle map. It's one of the keys to making the car more enjoyable to drive. I did mine -- did I mention I love the OS tuning tools? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 11, 2007 Share Posted February 11, 2007 Here's an example. I copied the 2005 STi stock throttle map to the 2005 LGT 5MT map. For me, I liked it better than stock but it was too "touchy". The top table is LGT stock and the bottom table is the 2005 STi throttle map. Notice how a small amount of foot pedal results in more throttle blade movement on the STi. Also, notice that the throttle blade never goes to 100% on the LGT map. http://i141.photobucket.com/albums/r69/mickeyd2005/throttlecontrol.jpg I finally bought a used AP 1.0 and am using the Cobb stage 2 OTS. I think it's smoother, but I don't know what the map looks like. Really a matter of personal preference. Link to comment Share on other sites More sharing options...
NSFW Posted February 11, 2007 Share Posted February 11, 2007 Crawdaddy's car is an 07; last I heard, those aren't yet tunable. HNRB4LGT, you should try logging to see if the problem really is throttle lag (i.e. the throttle actuator lags behind the pedal) or turbo lag (i.e. torque lags behind the actuator). The cable is $80 from http://www.tactrix.com, and the software is free from http://www.enginuity.com . MickeyD, the "only goes to 80" think might just be a bug in the way the data is displayed - did you see this thread? http://www.enginuity.org/viewtopic.php?t=1225&postdays=0&postorder=asc&start=0 Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 11, 2007 Share Posted February 11, 2007 OP has an 05. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted February 11, 2007 Share Posted February 11, 2007 I copied the throttle map from the stock 2005 STi which I thought had a similar 32 bit ECU. In hindsight, I do recall datalogging my stock car and it was able to attain 100% throttle, so you're probably right. It's probably an error in interpretation of the map which means that when I copied the STi map it made it twice as twitchy as I thought which probably explains a lot. Link to comment Share on other sites More sharing options...
BDII Posted February 11, 2007 Share Posted February 11, 2007 man, the greatest flaw of the legacy is truly the laggy e- throttle. Anybody know where to get a different throttle body? Will the ecu let you do that? if your 5EAT, PM TDC he has TPC maps that will help Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Scooter Posted February 11, 2007 Share Posted February 11, 2007 ^^ I think they were called TPS maps, not TPC maps. IIRC, Jon at TDC developed them, but then decided he didn't really care for them, after all, so I'm not sure they are still available. Seek first to understand, then to be understood. In other words: SEARCH before you post! Link to comment Share on other sites More sharing options...
pillboy Posted February 11, 2007 Share Posted February 11, 2007 I my electronic throttle. SO much better than what is on my wife's '02 NA Outback. It is still ugly. Link to comment Share on other sites More sharing options...
John M Posted February 11, 2007 Share Posted February 11, 2007 A direct copy of the STi throttle map is way too agressive -- I tried that one first. Now I'm running another one from the osecuroms site that's much more linear. Link to comment Share on other sites More sharing options...
HNRB4LGT Posted February 12, 2007 Author Share Posted February 12, 2007 you think the the sti throttle mapping would be good for a 5EAT? For the last time, my car is not a Camry Link to comment Share on other sites More sharing options...
KGreb Posted February 12, 2007 Share Posted February 12, 2007 Like it or not, e-throttle is here to stay. Most of the lumps in the throttle map which people complain about are there to help smooth driver inputs and enable cleaner emissions. STI gets a different throttle map because Subaru chooses to submit the STI into a different (more lenient) emissions category. Link to comment Share on other sites More sharing options...
edkwon Posted February 12, 2007 Share Posted February 12, 2007 My throttle is just fine, its a huge improvement when i need to feather the throttle in stop n go traffic, it doesnt lurch all over the place like my impreza's mechanical linkage does. Ed Link to comment Share on other sites More sharing options...
John M Posted February 12, 2007 Share Posted February 12, 2007 you think the the sti throttle mapping would be good for a 5EAT? Not really, for the same reason as has been linked to above regarding the throttle values, ie. in the LGT the value of 80 can very well represent 100% throttle opening. If that's the case (and my experience says it probably is), the STi's map will have you at >50% throttle right off idle. It was fun but I got tired of rocketing away from every stop -- literally launching the car involuntarily because of the throttle's calibration. The map I'm using now was designed (not by me) to be very progressive and linear and it has restored the perfect response to pedal input. Link to comment Share on other sites More sharing options...
