Max Capacity Posted October 20, 2004 Share Posted October 20, 2004 Just got all the pieces to put my 6 y/o Thule Summit ski box on my 05GT Wagon. As I figured the wing hit's the box. It looks like I will have to also buy the Sedan mount kit from Thule and use half the mount kit over the front doors and use half of the rail kit over the rear doors so I can slide the box forward enough so I can open the rear hatch and the wing will not hit the box. I had to do this on my 98GT Wagon. My 00GT Wagon didn't have the wing option so it was fine. Why can't Subaru figure this out and make the rails go further forward on the roof. Audi and Volvo seem to have it figured out. I called them and told them of this problem back in 98. Just goes to show you how much they listen to the owners. I'm sure I'm not the only one with this problem. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Cascade-LGT Posted October 21, 2004 Share Posted October 21, 2004 [size=1]I had '97 and '00 wagons and experienced the same problem. Used stand alone "feet" on the '97 and removed the wing on the '00. I was using a Yakima Space Case. I replaced that box with a Thule Evolution 1200 (pretty compact -good thing skis keep getting shorter) which I had on my WRX wagon. I have not tried it yet, but it seems the mounting positions of the Thule will allow it to be placed far enough forward to clear the wing. If it does not clear, I'll probably try to modify mounting position. I want avoid the direct mounting as I always had marring of the paint where "feet" pads contacted the roof. [/size] Link to comment Share on other sites More sharing options...
GT Ski Posted October 21, 2004 Share Posted October 21, 2004 Grrr! I was looking a Thule Ski box for my wagon too... guess I'll stick with the normal ski clamps. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2004 Author Share Posted October 21, 2004 Another thought is to buy some Aluminum channel and redrill the box, move it forward and attach the channel to the box to stiffen it. My box tends to travel pretty fast sometimes. So I might bite the bullet and get the Sedan mounts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GT Ski Posted October 21, 2004 Share Posted October 21, 2004 Actualy, now that I think about it some of the newer Thule Ski boxes do have adjustments to move the box mount points fore and aft. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2004 Author Share Posted October 21, 2004 But think of what happens when you move the box forward. Think about all the air that wants to left the bottom of the box off the car. I just called my local shop to see if they can get the Sedan mount kit. Yes, some of the new box's are different lenghts but I don't want to go to short. I have a to put SG and DH skis in there sometimes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GT Ski Posted October 21, 2004 Share Posted October 21, 2004 That is true, but I used to sell them when I worked for REI during my College years. The new latch system is very sercure. How long are your skis btw? Link to comment Share on other sites More sharing options...
P06781 Posted October 21, 2004 Share Posted October 21, 2004 I redrilled the holes on mine for my outback long ago and it worked great . I left about 1" to back of wing. I did not reinforce it with anything and never had any problems. I put 4 pairs skis and 2 snowboards in it with no problems . However, I dont load the front with anything heavy . I will post a pic of it on my Gt wagon if you want . Jim Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2004 Author Share Posted October 21, 2004 If you could post a photo that would be great. But like I said earlier I have allready drilled the box and move it forward about 6 inches. GT skis, mine are 177cm and 170cm. I have a friends daughter that I sometimes stuffle around. She goes to one of the Ski Acedemy's as is being trained for SG and DH. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GT Ski Posted October 21, 2004 Share Posted October 21, 2004 I'm 6'3" 190lbs and I'm sliding on 168s. At least you are not hauling around some old school 210s :) Link to comment Share on other sites More sharing options...
STiSubie109 Posted October 21, 2004 Share Posted October 21, 2004 are the thule feet out for the legacy gt wagon rails? their website still dosent bring up anything. and what shop did you find them at? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 21, 2004 Author Share Posted October 21, 2004 Yes, I have mine already. Long story, but I have been in contact with Thule Sweden. I had Competitive Edge in East Longmeadow Ma order the Thule rack for me. I'm sure any good ski shop can get the rack. GT ski, Don't worry I ski every weekend and have more skis then I need sometimes. Both my son and I work in VT on the weekends. I've come from 203's back in 1996 to 170cm as my everyday skis. Thanks for caring, Don't worry, we're gear freaks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
apexjapan2 Posted October 22, 2004 Share Posted October 22, 2004 Well, until recently I used old skool 207s, but the wagon (BG5) was never a problem. I was looking at a box, but is was never going to fit, so that was out... Subaru had a box, but it was BIG bux, so gave up on that idea entirely and stuck with racks. However, my sedan (BE5) had issues with them on the roof - the top of the wing was getting a hammering ;) So now I use shorter skis and have no issues, but I carry them inside to help fuel economy now :) FWIW, I've seen peeps with modded boxes, they seem to be OK. Only ever seen one on an expressway, well the remains ;) But it had come off a Toyota... Cheers :) Link to comment Share on other sites More sharing options...
GT Ski Posted October 22, 2004 Share Posted October 22, 2004 I still see plenty 200+ cm skis on the hill where I teach, some people just don't want to let 'em go. My '96 OB did not have a spoiler so I had no problems, but the GT might pose a problem with the Thule box I was looking at. Oh hey Max, does the Thule rack lock by any chance? I know the Yakima rack does not. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 22, 2004 Author Share Posted October 22, 2004 You can buy the locks for it or use your old locks, just punch out the plastic plugs. As for ski lenght, most skiers in VT or up to date. Shorter is better. In some cases. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ChE Outback XT Posted February 24, 2005 Share Posted February 24, 2005 [quote name='GT Ski']Actualy, now that I think about it some of the newer Thule Ski boxes do have adjustments to move the box mount points fore and aft.[/QUOTE] I'm sorry, but I cringe every time I see skis out in the open. Salt + skis = lots and lots of oxydation. Maybe it's because I'm a racer and an engineer, but I just couldn't do that to skis. A new set of race skis (or a freshly stoneground pair) needs 60 layers of wax to reach its potential (Finish study). Back when I was racing full-time that was a lot of waxing for 5 or 6 new pairs of skis each year. I have an Evolution 1200 box on my OBXT, and it's great. A recent experiment even suggested that it doesn't affect my freeway mileage (300 miles, flat freeway, 75-80mph, 20.1-20.3mpg with or without box). There is the rear-wing issue, but I can still open the back enough to get everything in and out. Between the box in the winter and kayaks in the summer, I may never see the hatch wide open. Link to comment Share on other sites More sharing options...
ChE Outback XT Posted February 24, 2005 Share Posted February 24, 2005 Sorry, GT Ski, that was supposed to quote your message where you talked about the ski clamps vs. a box. Link to comment Share on other sites More sharing options...
MrVvrroomm Posted February 24, 2005 Share Posted February 24, 2005 I never even tried to mount my Thule on my Legacy. I did some measurements and knew it was a no go. I don't have any problem in my wagon with my couple of pairs of 187cm's. If we go out with the whole family, we take the minivan with the box. Link to comment Share on other sites More sharing options...
add_rock Posted November 28, 2005 Share Posted November 28, 2005 Has anyone out there gotten a ski box to fit on your wagon? If so, can you post some pics w/an explanation of how you made it fit? Thanks! Link to comment Share on other sites More sharing options...
NY Dragon Slayer Posted November 28, 2005 Share Posted November 28, 2005 some pics of my 175's Link to comment Share on other sites More sharing options...
add_rock Posted November 28, 2005 Share Posted November 28, 2005 [quote name='NY Dragon Slayer']some pics of my 175's[/quote] :icon_ques You forgot to post the pics. Link to comment Share on other sites More sharing options...
NY Dragon Slayer Posted November 28, 2005 Share Posted November 28, 2005 Here Ae Some Pics If I Did It Right Link to comment Share on other sites More sharing options...
NY Dragon Slayer Posted November 28, 2005 Share Posted November 28, 2005 Having Link to comment Share on other sites More sharing options...
NY Dragon Slayer Posted November 28, 2005 Share Posted November 28, 2005 Heres Some More Link to comment Share on other sites More sharing options...
iguanamafia Posted November 29, 2005 Share Posted November 29, 2005 How high does the hatch go up on the wagon with the box? Is it still possible to access the trunk? How about using a tether to the top of the strut to the bottom of the strut so that the hatch wont go up all the way (if the trunk is accessible). Thats what I did on my WRX Wagon, I could still get in the trunk, it just stopped the spoiler short of hitting my snowboards on the roof. Link to comment Share on other sites More sharing options...
