Nickz31se-r Posted January 30, 2007 Share Posted January 30, 2007 I still need to order gaskets so I can install the UP and DP that I have had lying around for over a month. Which way is easiest. This will obviously deduce which gaskets I will buy, so ...........survey says? Link to comment Share on other sites More sharing options...
Waxiboy Posted January 30, 2007 Share Posted January 30, 2007 Remove the entire piece as one. I think you will even unscrew less bolts this way...mostly on X-pipe heatshield. Link to comment Share on other sites More sharing options...
sgt Posted January 30, 2007 Share Posted January 30, 2007 I just removed the passenger side alone and left the crossover pipe installed, However waxiboy does make a point, but that thing is heavy! Link to comment Share on other sites More sharing options...
suds2250 Posted January 30, 2007 Share Posted January 30, 2007 The crossover pipe is harder to seal. Much easier to remove the manifolds. 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
whitetiger Posted January 30, 2007 Share Posted January 30, 2007 remove the whole thing. the center heat sheild is a bitch to remove and install. Link to comment Share on other sites More sharing options...
Edgemar Posted February 14, 2007 Share Posted February 14, 2007 Can you install the UP without removing the manifold. Also, is it wise to replace the manifold to head gaskets if it needs to come off? Link to comment Share on other sites More sharing options...
Edgemar Posted February 14, 2007 Share Posted February 14, 2007 answered my question in this thread: http://www.legacygt.com/forums/showthread.php?t=42715&highlight=install+manifold manifold should come out. You can reuse manifold to head gaskets some people do some don't. Link to comment Share on other sites More sharing options...
FourMoBro Posted February 14, 2007 Share Posted February 14, 2007 Just remove the whole thing and throw in the trash, but save the bolts and nuts. Install Perrin EL headers in its place. Link to comment Share on other sites More sharing options...
rkl303 Posted February 14, 2007 Share Posted February 14, 2007 Or sell it to crucial for $50 or get them crucialized. Link to comment Share on other sites More sharing options...
GTTuner Posted February 14, 2007 Share Posted February 14, 2007 Remove the entire piece as one. I think you will even unscrew less bolts this way...mostly on X-pipe heatshield. ^^^^^^^^+1 This is how I did mine. Link to comment Share on other sites More sharing options...
Boostjunkie Posted February 15, 2007 Share Posted February 15, 2007 I have been doing them by removing the whole manifold, but for giggles on the last car I only removed the passenger side manifold. I actually found it quicker and easier, although YMMV. Link to comment Share on other sites More sharing options...
Nickz31se-r Posted February 16, 2007 Author Share Posted February 16, 2007 I have been doing them by removing the whole manifold, but for giggles on the last car I only removed the passenger side manifold. I actually found it quicker and easier, although YMMV. For giggles. You sir must be a glutton for punishment, nice to see it worked out for you. I still have yet to order gaskets or a drop in filter, but I have had my AP, UP and DP since Oct. I guess I have become incredibly lazy or the stock power is just enough not to enoy. The suspension and wheels were done within a month of me having the car, aka the suspension was crap. Link to comment Share on other sites More sharing options...
Joon525 Posted February 18, 2007 Share Posted February 18, 2007 I just removed the passenger side alone and left the crossover pipe installed, However waxiboy does make a point, but that thing is heavy! I did the same with no problem. Link to comment Share on other sites More sharing options...
highlander Posted February 18, 2007 Share Posted February 18, 2007 If you have access to a lift or tall jack stands, then take the whole assembly off as a unit. Remove the upper EGT sensor before dropping the assembly. Then you should be able to rotate the UP out easily without loosing the motor mounts. If you can't get that much ground clearance then do the passenger side only. The crossover pipe doesn't have to come off if you do it this way. Vir Est Fatum Ut Perficio Concepta Suus Progenies. - Man is destined to fulfill the capacity of his lineage (i.e. Darwinism) Link to comment Share on other sites More sharing options...
unstablementaly Posted February 18, 2007 Share Posted February 18, 2007 wow, i did my UP and DP today. and i didn't go thru half the crap you guys are talking about! but i did have a lift and air tools at my disposal. just one bolt for the motor mount. after you've unbolted the UP on both ends jack the engine up about 2 inches and the UP rotates right out. my entire install took under 2 hours. my vBGarage Link to comment Share on other sites More sharing options...
