Nachowang Posted January 22, 2007 Share Posted January 22, 2007 So im noticing that im loosing about 20 psi of air every week on one of my tires. I have pulled the wheel to inspect for dents, valve, the tire itself, and applied water and soap on the tires which all came out negative. I'm thinking the tire needs to be remounted and balanced on the rims since i might have hit one of the many potholes around the tri state area causing it to "shift", is there such a thing? Link to comment Share on other sites More sharing options...
Repsak Posted January 22, 2007 Share Posted January 22, 2007 Set the tire psi to like 50 Put it in a tub full of water and look for airbubbles. If you dont see anything double check the vavle core/valve stem. Then check the bead. You might have to break the tire down to inspect it a little bit more. the key is boosting up the psi so more air will squeeze out of the tire to make it a little more obvious. If you cant get a tub of water try soapy water and spray the whole thing down. Link to comment Share on other sites More sharing options...
wukindada Posted January 22, 2007 Share Posted January 22, 2007 Sounds like a valve stem issue...... As rep mentioned, a spray bottle & soapy water is your best bet;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
PGT Posted January 22, 2007 Share Posted January 22, 2007 I did all this and came up empty. Turns out it was a dirty rim bead and the tire wasn't sealing properly when driven (meaning I couldn't find the leak the normal way). Taking the tire off the rim, cleaning the mounting surface and remounting did the trick - a local shop charged me $20, which was more than fair. Now, the dealer that mounted all four tires the week prior, well, let's just say they sucked. Link to comment Share on other sites More sharing options...
Nachowang Posted January 23, 2007 Author Share Posted January 23, 2007 I did all this and came up empty. Turns out it was a dirty rim bead and the tire wasn't sealing properly when driven (meaning I couldn't find the leak the normal way). Taking the tire off the rim, cleaning the mounting surface and remounting did the trick - a local shop charged me $20, which was more than fair. Now, the dealer that mounted all four tires the week prior, well, let's just say they sucked. i'm thinking this might be my problem Link to comment Share on other sites More sharing options...
TRS Posted January 23, 2007 Share Posted January 23, 2007 I've had that problem a couple times over the years. A tire shop should be able to do the dismount, mounting surface cleaning/smoothing, remount and balance no problem for a reasonable price. Link to comment Share on other sites More sharing options...
Repsak Posted January 23, 2007 Share Posted January 23, 2007 crush the tire slap some bead sealer on it then blow the tire back up again thats all you need... This is prolly due to a corrosion issue where the rim/tire meet. Im suprised to be hearing about this in 05's I usualy only head about it from 91-99 cars, or cars with high milage. Link to comment Share on other sites More sharing options...
Nachowang Posted January 24, 2007 Author Share Posted January 24, 2007 crush the tire slap some bead sealer on it then blow the tire back up again thats all you need... This is prolly due to a corrosion issue where the rim/tire meet. Im suprised to be hearing about this in 05's I usualy only head about it from 91-99 cars, or cars with high milage. It's not on stocker, these are aftermarket and I got a feeling the seal most likely popped going through a pothole. I'm getting it checked this weekend. Link to comment Share on other sites More sharing options...
Repsak Posted January 25, 2007 Share Posted January 25, 2007 hmm weird, that doesnt happen too often. Link to comment Share on other sites More sharing options...
Scooby Fan Posted January 25, 2007 Share Posted January 25, 2007 Check to see if you have a porous rim....some mags have air bubbles in the castings that will allow a slow leak from the rim itself!! I had a set of FRD rims a few years ago.......3 of the 4 had to be replaced for this problem....needless to say...the whole set was returned to the dealer. When you inflate them and dip them into the tank, check around the inside of the rim itself. Link to comment Share on other sites More sharing options...
Nachowang Posted January 29, 2007 Author Share Posted January 29, 2007 Problem solved, the tires were remounted, sealed, and balanced again. Link to comment Share on other sites More sharing options...
