alphabit Posted January 22, 2007 Share Posted January 22, 2007 I say Floor it and pull the hand brake and jerk the wheel left of right, if your in trouble, might as well make it worse. however: I would guess you have at least a bent control arm, bent rim. So at minimum you would need a new control arm and rim and the parts and labour that go along with that. You would also need an alignment for sure. Hope that helps. is good advice, and you would need to start look into the price of this, but could be anywhere from 500-900? CDN of course thats just a quote out of what I think and could be a complete farse, but not to far off? I don't know I am not a doctor. Link to comment Share on other sites More sharing options...
bdisco Posted January 22, 2007 Share Posted January 22, 2007 I say Floor it and pull the hand brake and jerk the wheel left of right, if your in trouble, might as well make it worse. + curb = roll over / yard sale. Link to comment Share on other sites More sharing options...
Scotty Posted January 22, 2007 Share Posted January 22, 2007 For the record, in general for AWD cars, gently apply throttle when you get into trouble and let the car save you. It works a lot better than you might think. Note that there is a point at which even AWD cannot pull you out of the mess you've gotten into. Part of the reason is by being on the throttle, the diffs are transfering power to where it has grip, if there is any. If you get off the gas, there's no power to transfer. Link to comment Share on other sites More sharing options...
Aczwild Posted January 22, 2007 Share Posted January 22, 2007 + curb = roll over / yard sale.:lol::lol::lol: JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
beatadrum Posted January 22, 2007 Author Share Posted January 22, 2007 ok so i took it to the subaru dealership today and they said the rim is bent (i already knew that tho) then also the shock and shock mount is messed up pretty bad too, and of course it is out of alignment....bout $550, i need to find someone to buy one good rim from though or thats another $300....apparently subaru dealerships dont carry their parts in stock so they have to order everything and should be done by friday.... Link to comment Share on other sites More sharing options...
red beast Posted January 23, 2007 Share Posted January 23, 2007 http://img.villagephotos.com/p/2003-10/423426/jesus2re92.jpg Link to comment Share on other sites More sharing options...
mccorry Posted January 23, 2007 Share Posted January 23, 2007 Sorry to hear about your issue.... Link to comment Share on other sites More sharing options...
Aczwild Posted January 23, 2007 Share Posted January 23, 2007 Check around for a rim straightening shop in your area, it will be alot cheaper than buying a new one unless you really really destroyed the rim. The guys at the shop will take the rim off and examine it and can tell you if they can fix it. Try that first before ordering a new one JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
mwiener2 Posted January 23, 2007 Share Posted January 23, 2007 RE92's kill bunnies My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
RobE Posted January 24, 2007 Share Posted January 24, 2007 sorry to hear about your misfortune. everybody makes mistakes, just make sure you learn from it. and then go upgrade tires . http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
Brady Posted January 24, 2007 Share Posted January 24, 2007 Part of the reason is by being on the throttle, the diffs are transfering power to where it has grip, if there is any. If you get off the gas, there's no power to transfer. This isn't true. At least not for the Manuals. In the manual transmission, the center diff is a viscous coupling unit. Doesn't matter whether power or torque is applied, it just tries to keep wheels spinning at similar speeds, so even under braking, the diff is working. In the GT with a Viscous rear diff as well, you have the rear wheels working with the center diff to keep everything moving the same. The front diff is open, so one wheel doesn't really care what the rest are doing. It's been a long time since I've dealt with Subaru's automatic transmission, but I think the hydraulic clutch pack will work under braking as well. If we had Torsen diffs (like the '07 Spec.B rear diff), then you would see a difference in performance under load. Link to comment Share on other sites More sharing options...
Anibalz Posted January 25, 2007 Share Posted January 25, 2007 ok so i took it to the subaru dealership today and they said the rim is bent (i already knew that tho) then also the shock and shock mount is messed up pretty bad too, and of course it is out of alignment....bout $550, i need to find someone to buy one good rim from though or thats another $300....apparently subaru dealerships dont carry their parts in stock so they have to order everything and should be done by friday.... I have an extra rim if you are interested! Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted January 25, 2007 Share Posted January 25, 2007 Thats it ... the RE92's are gone as soon as possible. I love my car ... basically. Link to comment Share on other sites More sharing options...
jagcars26 Posted January 25, 2007 Share Posted January 25, 2007 Wait a minute,,the 07 2.5i Limited comes with RE92s?? My wifes 06 came stock with Yokahama A/S. Link to comment Share on other sites More sharing options...
06White2.5I Posted January 25, 2007 Share Posted January 25, 2007 http://i22.photobucket.com/albums/b345/Undergr0undAssassins/sgoat.jpg Have Camera...Will Travel ~2007 LegacyGT.com Calendar (October)~ Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted January 25, 2007 Share Posted January 25, 2007 this is turning into an RE 92 thread lol. I love my car ... basically. Link to comment Share on other sites More sharing options...
moviemadness Posted January 25, 2007 Share Posted January 25, 2007 Haha, sorry I thought you were the guy that couldnt find the port to plug in the AP, hahaha i wouldnt be surprised if that guy gets into an accident. Still tkae it easy, hydro planing at 25. you talking about me? Link to comment Share on other sites More sharing options...
Guest Gitster Posted January 25, 2007 Share Posted January 25, 2007 Absolutely! Link to comment Share on other sites More sharing options...
moviemadness Posted January 25, 2007 Share Posted January 25, 2007 suuuure. Link to comment Share on other sites More sharing options...
06White2.5I Posted January 25, 2007 Share Posted January 25, 2007 Fight! Fight! Fight! Have Camera...Will Travel ~2007 LegacyGT.com Calendar (October)~ Link to comment Share on other sites More sharing options...
moviemadness Posted January 25, 2007 Share Posted January 25, 2007 promise not to call cops or press charges, and no guns or knives, i'm down. j/k Link to comment Share on other sites More sharing options...
jagcars26 Posted January 25, 2007 Share Posted January 25, 2007 Wait a minute,,the 07 2.5i Limited comes with RE92s?? My wifes 06 came stock with Yokahama A/S. Bump fr an answer cause I'm curious. Link to comment Share on other sites More sharing options...
ebpda9 Posted January 25, 2007 Share Posted January 25, 2007 i think the re92's were discontinued back in 05. Link to comment Share on other sites More sharing options...
06White2.5I Posted January 25, 2007 Share Posted January 25, 2007 Bump fr an answer cause I'm curious. It's true, my 06 2.5i came with the Yokos. Have Camera...Will Travel ~2007 LegacyGT.com Calendar (October)~ Link to comment Share on other sites More sharing options...
robinlsb Posted January 25, 2007 Share Posted January 25, 2007 hydro plane at 25? You can easily aquaplane any tire when the water depth is greater than the tread depth. When the water depth is greater than the tread depth at speeds of even 15 mph you are in a quatramaran, and the tires are just rudders!!!! Once the water depth exceeds the tread depth the only two variables left are speed and weight on tire. Something to remember when you drive in a spirited manner in the rain. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
