RS22b Posted December 4, 2006 Share Posted December 4, 2006 Obviously the STi hubs wont bolt onto my Outback. What have ppl done about the Brembos in the rear? I hear of some bracket needed, but who makes it and where can i get it and how much? Thanks for the input. _billy Link to comment Share on other sites More sharing options...
AWDxBOOST Posted December 4, 2006 Share Posted December 4, 2006 yep brackets talk to TDC or mach v i believe would be your best bets Link to comment Share on other sites More sharing options...
RS22b Posted December 4, 2006 Author Share Posted December 4, 2006 great thanks. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 4, 2006 Share Posted December 4, 2006 What do you plan to do with the rotors? Are you going to swap out the hubs? Or get custom rotors made? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 4, 2006 Share Posted December 4, 2006 get rotors for an 04 sti My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 4, 2006 Share Posted December 4, 2006 ^^^ AFAIK, the parking brake is different... but please correct me if I'm wrong. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted December 4, 2006 Share Posted December 4, 2006 it is, but arent we keeping the stock integrated parking brake anyways when you just bolt on calipers and rotors? Link to comment Share on other sites More sharing options...
SnoDork Posted December 4, 2006 Share Posted December 4, 2006 Here: http://www.legacygt.com/forums/showthread.php?t=33418 ~Sucka-Duck~ Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 4, 2006 Share Posted December 4, 2006 blank Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted December 4, 2006 Share Posted December 4, 2006 speak to edmundu. he knows the deal. Jesse Link to comment Share on other sites More sharing options...
Boostjunkie Posted December 4, 2006 Share Posted December 4, 2006 The stock STi rear rotors will not work if you want to have a parking brake. The parking brake is basically a drum brake that presses the shoes against the inside of the rear rotor. The inner diameter of the STi rotor is larger than that of the LGT/WRX rotor, which makes it impossible for the parking brake to engage (the shoes won't reach are enough). The solution is a special rotor tha Brembo makes for the application, or getting a pressed in sleeve that Godspeed sells put into the STi rotor. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 4, 2006 Share Posted December 4, 2006 Do you have the link to Godspeed's home page or to someone who sells their adapter rings? I google Godspeed, but ended up with a bunch of weird stuff. Link to comment Share on other sites More sharing options...
KA81 Posted December 4, 2006 Share Posted December 4, 2006 Godspeed, maybe? found this on forums too Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 5, 2006 Share Posted December 5, 2006 The solution is a special rotor tha Brembo makes for the application, or getting a pressed in sleeve that Godspeed sells put into the STi rotor. The first thing that came to mind was... isn't this dangerous to rely on a press fit? I looked at the link that KA81 provided, the Godspeed modification appears to be thicker braker shoes and not a giant press in bushing. I don't know anyone who sells this, but at 200 pounds sterling, it should be competitve considering I've seen STi rear calipers sell very cheaply on Nabisco. WRXBrakes on Nabisco appears to be gaging interest in a custom rotor for the WRX. http://forums.nasioc.com/forums/showthread.php?t=1136862&page=2&highlight=godspeed+brembo Link to comment Share on other sites More sharing options...
Boostjunkie Posted December 5, 2006 Share Posted December 5, 2006 I know a local guy who just bought the Godspeed rotor inserts and rear Brembo mounting bracket kit. I held them in my hands yesterday. Actually he said all you do to install the inserts is put the rings in the freezer to shrink a tiny bit and then they slid right into the rotors. Once they heat up and expand they are basically locked in there. If you are interested in more info you can PM Hybrid22L. There is a custom rotor already from Brembo. Problem is that they cost $300/ea. Link to comment Share on other sites More sharing options...
edmundu Posted December 5, 2006 Share Posted December 5, 2006 Like other's have mentioned....You have BBK kit from Brembo, you can have inserts put into Sti rotor's to retain the parking brakes, I have also seen custom parking brake shoes.(I would do that, as they are less expensive, and I have never found anyone to wear out the PB shoes anyway...And if you ever need to replace a rotor, it will be easier/cheaper to find a std Sti one.) My setup, was from TWR Racing, they custom made 2pc Rotor's, that have the correct drumb diameter, and custom brackets to locate the caliper correctly. These are nice lightweight billet Aluminum hubs, and as such, you cannot use the PB as an ebrake, or to kick the rear end around.(Al has a low melting -point!) But for its intended use it works flawlessly. I'm not sure if they are still offering the kit, as last I heard, it was costing too much $$$ for materials/machining. Link to comment Share on other sites More sharing options...
Rommel Posted December 5, 2006 Share Posted December 5, 2006 TWR Racing stopped selling the rotors last time I talked to them. The supplier was asking too much $$ so it's not practical to sell them any more. I bought the Brembo rotors and it is expensive. Link to comment Share on other sites More sharing options...
RS22b Posted December 5, 2006 Author Share Posted December 5, 2006 great! thanks for the link. I think i might actually go with those over-sized ebrake shoes and caliper brackets. i would really like to get the whole set on in one shot rather than running my stockers in the rear till DBA and kartboy come out with new rotors and brackets. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted December 5, 2006 Share Posted December 5, 2006 ^^^ If you get the kit, let us know where you can get them and how they worked out. I emailed Godspeed UK but didn't get a response. Link to comment Share on other sites More sharing options...
RS22b Posted December 6, 2006 Author Share Posted December 6, 2006 i'll let you know as soon as i actually do this whole thing, but the 6spd is the first thing in, then the brakes. Link to comment Share on other sites More sharing options...
Ian Godney Posted January 16, 2007 Share Posted January 16, 2007 Hi Mickey For some reason your email got sent to my junk mail folder by our server , I only got it today after searching for another email that I didnt get , so hopefully you should have a reply now , I dont know what size discs you have fitted as I think they maybe different to what is fitted over here in the UK , if you have a measure up , if you have the 266mm rear discs fitted then the kit we supply is suitable. http://www.godspeedbrakes.co.uk/Subaru/Rear/Rear_classic.htm http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280071169872 Cheers Ian Link to comment Share on other sites More sharing options...
mickeyd2005 Posted January 16, 2007 Share Posted January 16, 2007 Ian, Thanks for your reply. I'm surprised you found this thread. Unfortunately, I wasn't able to find a decent affordable STi rear brake solution so I went with a Racing Brake setup. Your setup sounds like a good one. However, the USDM LGT rear brakes are 290 mm x 18 mm. I believe that the Outback uses 266 mm rear brakes and maybe the WRX. Do you have 290 mm rear brakes on a European Subaru? I was under the impression that the rear STi brackets work with both sizes? Not sure. Posting your products on eBay would give US customers a chance to find them more easily. Can you edit your eBay auction to include US shipping charges? Maybe someone with an Outback might want to try this. Link to comment Share on other sites More sharing options...
sgt Posted January 16, 2007 Share Posted January 16, 2007 Any kit that works for the wrx should work for the lgt, but like the brembo GT kits they might require slight modification Link to comment Share on other sites More sharing options...
Ian Godney Posted January 16, 2007 Share Posted January 16, 2007 Yes our 2001 onwards Impreza WRX has 290mm rear discs , the STi has the 316mm ones with the gold Brembo's , the brembo set up fits straight on the WRX with the thicker shoes needed to take up the difference in E brake size Cheers Ian Link to comment Share on other sites More sharing options...
