kkushner4474 Posted December 3, 2006 Share Posted December 3, 2006 How do you release the fuel pressure in a 99 DOHC 2.5L Legacy Gt 5MT N/A. The service manual i own does not have the refrence page i need. I need this so i can replace fuel injectors. Link to comment Share on other sites More sharing options...
rao Posted December 3, 2006 Share Posted December 3, 2006 Pull the fuel pump relay with the car running or don't worry about it and just put some rags around the area where you first open up the system. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
dplacen Posted December 4, 2006 Share Posted December 4, 2006 I usually remove the gas cap. But you may still get a bit of pressure but not as much. Link to comment Share on other sites More sharing options...
