mwr Posted November 1, 2006 Share Posted November 1, 2006 Does anyone in the SF Bay Area have a 2005 or later LGT Wagon with: - JDM GT Bilstein (or USDM SpecB Bilstein) front and rear dampers and stock JDM springs. No other suspension mods. That setup has been recommended to me as giving 99% stock comfort and 400% stock handling. - The above + JDM GT rear sway bar. - JDM GT rear sway bar only. Thanks! Link to comment Share on other sites More sharing options...
leggtnut Posted November 1, 2006 Share Posted November 1, 2006 This is what I want to do with my sedan + swaybars (front and rear). Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
Huey Posted November 1, 2006 Share Posted November 1, 2006 Not quite what you are looking for but here is my set-up. 2006 LGT sedan JDM GT wagon bilsteins front and rear JDM Wangan springs (similar to pinks but with a slightly higher ride height) Cusco front and rear sways Cusco front and rear under body bars stock wheels and tires The ride is firmer then stock, but no where close to harsh. I've found this to be perfect for me since I go to lunch with co-workers and they hardly noticed anything had changed (they aren't car people). It handles far better then stock, with no more lean and much more controled ride. Link to comment Share on other sites More sharing options...
dvdt Posted November 1, 2006 Share Posted November 1, 2006 ...The ride is firmer then stock, but no where close to harsh. .... Just wait until you get 18's. Huey's car handles surprisingly well w/ this set-up even w/ stock tires. Link to comment Share on other sites More sharing options...
Spinjockey Posted November 1, 2006 Share Posted November 1, 2006 - JDM GT Bilstein (or USDM SpecB Bilstein) front and rear dampers and stock JDM springs. No other suspension mods. That setup has been recommended to me as giving 99% stock comfort and 400% stock handling. Wouldn't this basically just be a spec-B? Link to comment Share on other sites More sharing options...
Guest Posted November 1, 2006 Share Posted November 1, 2006 Wouldn't this basically just be a spec-B? JDM GT springs (including JDM Rev. C which has the same dampers as USDM SpecB) are different than 2006 SpecB. Most likely stiffer. 2007 USDM SpecB has different springs, not unlikely same as JDM GT (Rev. D). But noone knows. Also JDM GT original revision are different than USDM SpecB. Possibly bit better damping. Link to comment Share on other sites More sharing options...
