rai Posted October 27, 2006 Share Posted October 27, 2006 I just got a NA legacy wagon with MT. I wonder if there is any difference b/t the NA and the turbo as far as clutch tranny AWD or suspension set-up? (talking non-spec.B of course). Link to comment Share on other sites More sharing options...
Th3Franz Posted October 27, 2006 Share Posted October 27, 2006 There is. I believe the suspension parts will swap but the GT has a slightly more aggressive suspension. I imagine the tranny and clutches are also different due to the big difference in power. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
LUKEGT03 Posted October 27, 2006 Share Posted October 27, 2006 I know the throwout bearing is different so the clutch setup is at least slightly different. Link to comment Share on other sites More sharing options...
Spinjockey Posted October 31, 2006 Share Posted October 31, 2006 Check out the vacation picts... It's smaller diameter (225mm vs 240mm) with "conventional" flywheel (not dual mass like LGT). Link to comment Share on other sites More sharing options...
