16psibrick Posted October 21, 2006 Share Posted October 21, 2006 car is a white 06 350z...the goals are: 1. good sound quality 2. complete use of trunk space (stealth) 3. clean but with a little flare lets get started: headunit: Pioneer 7800MP installed using the metra 06 Z kit: http://simplicity.elitecaraudio.org/sean1.jpg the front stage uses a pair of Polk Audio Signature Reference 6.5" comp set (mounted coaxially) in a set of Wicked CAS door pods. The inside of the door pod is compeltely dampened with Edead, as is the inside of hte plastic door panel. while it was a huge pain to pull suede across the curvy shape, i managed to do it with lots of tugging and swearing http://simplicity.elitecaraudio.org/sean10.jpg http://simplicity.elitecaraudio.org/sean11.jpg http://simplicity.elitecaraudio.org/sean12.jpg Link to comment Share on other sites More sharing options...
16psibrick Posted October 21, 2006 Author Share Posted October 21, 2006 the trunk is obviously hte main attraction, here is what it looks like all covered, up, as you can see the floor hasnt been raised at all http://simplicity.elitecaraudio.org/sean2.jpg take out the two layers of carpet and you are greated with this: http://simplicity.elitecaraudio.org/sean3.jpg http://simplicity.elitecaraudio.org/sean4.jpg covers protect and hide all the components, and a combination vinyl/sude makes up the floor theme. the center is a mesh grill covered in grile cloth to protect the subs and with all the covers off, its all revealed Two Elemental Designs nine2x flank a pair of Ed 11kv black cones, infront of the amps are the two monstrous crossover modules from the Polk SR set. two tone black vinyl with white suede flows across the entire floor... sounds pretty decent as well, the two 11kvs provide more than enough bass in the little Z to shake hairs and rattle mirrors, and they even provide clean bass with the carpet on http://simplicity.elitecaraudio.org/sean5.jpg http://simplicity.elitecaraudio.org/sean6.jpg http://simplicity.elitecaraudio.org/sean7.jpg http://simplicity.elitecaraudio.org/sean8.jpg http://simplicity.elitecaraudio.org/sean9.jpg Link to comment Share on other sites More sharing options...
16psibrick Posted October 21, 2006 Author Share Posted October 21, 2006 and here are a few behind the scenes shots to show some of the attention to detail: first you can see the pods thare dampened as well as the doors, semi-permiable carpet and a piece of foam dampening gives the pod a semi-sealed enclosure. note TWO pairs of new speaker wires are run into the door via the factory molex plug http://simplicity.elitecaraudio.org/sean13.jpg http://simplicity.elitecaraudio.org/sean14.jpg http://simplicity.elitecaraudio.org/sean15.jpg and here is the trunk with all the floor off, showing that there arent flying wires every where http://simplicity.elitecaraudio.org/sean16.jpg Link to comment Share on other sites More sharing options...
leggtnut Posted October 21, 2006 Share Posted October 21, 2006 16psibrick, you do such good work. It really makes me wish I had the $$ to let you have fun with my LGT Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
PGT Posted October 21, 2006 Share Posted October 21, 2006 yeah....what's the bill rate? will you accept good meals and free beer in exchange for discount? Nice work as always!! Link to comment Share on other sites More sharing options...
VTsullyman Posted October 21, 2006 Share Posted October 21, 2006 Nice set up too bad its a Z. 2007 DGM LGT 2003 Suzuki SV650S Link to comment Share on other sites More sharing options...
Boulderguy Posted October 21, 2006 Share Posted October 21, 2006 You've done it again - nice! Especially like the super clean pods & the non-PGT wiring job around the trunk... [just call me zip-tie boy] If I could change anything about it I'd spend an extra few hundred for a custom 'glas dash mount over the Metra for a little more flair, not that it needs it but I just can't leave well enough alone. Keep sending the pics of new systems! Link to comment Share on other sites More sharing options...
laz Posted October 21, 2006 Share Posted October 21, 2006 vey nice! It makes me want to clean up my trunk (don't even have a system) when I see your tidy work. X --- Link to comment Share on other sites More sharing options...
PGT Posted October 21, 2006 Share Posted October 21, 2006 You've done it again - nice! Especially like the super clean pods & the non-PGT wiring job around the trunk... [just call me zip-tie boy] If I could change anything about it I'd spend an extra few hundred for a custom 'glas dash mount over the Metra for a little more flair, not that it needs it but I just can't leave well enough alone. Keep sending the pics of new systems! function > form Link to comment Share on other sites More sharing options...
Dsfa Posted October 22, 2006 Share Posted October 22, 2006 You are really talented ! I look forward to seeing your installs no matter what car it is. Link to comment Share on other sites More sharing options...
16psibrick Posted October 25, 2006 Author Share Posted October 25, 2006 next up is a car i have never done before new IS350 belonging sadly to a former LGT forum member hehe Link to comment Share on other sites More sharing options...
Sobrry01 Posted October 25, 2006 Share Posted October 25, 2006 IS350? He is replacing the Mark Levinson system? My dad has one of those and it is by far the best car stereo I have heard. Link to comment Share on other sites More sharing options...
biz77 Posted October 25, 2006 Share Posted October 25, 2006 Looks very well put together per your usual work. How do you like the Polk SR components? I'm thinking about accomodating a set for the Legacy. Link to comment Share on other sites More sharing options...
ron_c1 Posted October 26, 2006 Share Posted October 26, 2006 IS350? He is replacing the Mark Levinson system? My dad has one of those and it is by far the best car stereo I have heard. No, I decided against that option. I already had equipment from my Legacy, and couldn't find a dealership that had an ML on the lot without all the other options that I can live without. Besides, I wanted 16psibrick to do an install in my car....had even thought about having him do my Legacy before I decided not to put more money into it. Link to comment Share on other sites More sharing options...
jazzymt Posted October 27, 2006 Share Posted October 27, 2006 As always - extremely nice work. Out of curiousity - what do you use to fab your custom Nylon pieces? [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
16psibrick Posted October 27, 2006 Author Share Posted October 27, 2006 what doy ou mean nylon piece? b Link to comment Share on other sites More sharing options...
jazzymt Posted October 27, 2006 Share Posted October 27, 2006 Er, you said Vinyl, not Nylon...mkay - so what is the white stuff? Just MDO? [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
16psibrick Posted October 27, 2006 Author Share Posted October 27, 2006 white stuff is suede, synthetic suede Link to comment Share on other sites More sharing options...
