mtenhoven Posted October 17, 2006 Share Posted October 17, 2006 What is the recommended replacement schedule for the clutch fluid? Thanks... Link to comment Share on other sites More sharing options...
Opie Posted October 22, 2006 Share Posted October 22, 2006 What is the recommended replacement schedule for the clutch fluid? Thanks... Since it is brake fluid in the clutch resevoir, I would replace it just as often as the brake fluid. Link to comment Share on other sites More sharing options...
pillboy Posted October 22, 2006 Share Posted October 22, 2006 I know what the next question is gonna be. It is still ugly. Link to comment Share on other sites More sharing options...
06 Legacy GT Posted October 23, 2006 Share Posted October 23, 2006 I don't believe there is a clutch fluid replace interval Link to comment Share on other sites More sharing options...
06 Legacy GT Posted October 24, 2006 Share Posted October 24, 2006 logic distates whenever the battery fluid gets replaced! Link to comment Share on other sites More sharing options...
GTTuner Posted October 25, 2006 Share Posted October 25, 2006 The brake fluid is recomended at 30k. I'd do both. Hey sebberry, that didn't happen to be a LeCar???? Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 25, 2006 Share Posted October 25, 2006 I remember when I was a kid, we had an old Renault and we had to fill up the battery My 00 Maxima (and father-in-laws 00 MPV) had unsealed batteries that I filed twice a year. They actually outlasted all of the sealed batteries I have ever owned. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
pillboy Posted October 25, 2006 Share Posted October 25, 2006 The brake fluid is recomended at 30k. I'd do both. Brake & clutch fluid are both hygroscopic fluids (they absorb water). Replace both at the same interval...every 2 years is what I have read in many different places. I have never had a corrosion related brake issue (or clutch with the Cherokee) by doing this. It is still ugly. Link to comment Share on other sites More sharing options...
Spinjockey Posted October 25, 2006 Share Posted October 25, 2006 I don't think I've ever had clutch fluid changed in my other car (84 camry that I drove for 12+ years). Power steering maybe once. Then again the brake fluid probably only got changed once or twice. For power steering fluid the shop manual says it should be changed "when highly deteriorated or contaminated" or if there was a leakage (couldn't find anything in the clutch section). So if power steering has a "infinite" life then I'd assume the clutch fluid does as well. I'd guess that the PS and Clutch systems are closed and don't let any air in, so you shouldn't be getting much water into the fluid. Plus there's no where near as much heat cycling as there is with brake fluid so I don't see how you'd get much deterioration. I figure at about a 100K I'll consider changing clutch/PS fluids. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 25, 2006 Share Posted October 25, 2006 Both clutch and ps fluid have breathers to the atmosphere because they expand with temperature. Therefore they both will absorb some water over time. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
GTTuner Posted October 25, 2006 Share Posted October 25, 2006 Look at the fluid in your master cylinder. If it is black or very dark, your overdue. You will be amazed at how much better the pedal feels after a flush. Usually the pedal is higher and firmer. And, as everyone agrees that brake fluid will absorb water, as it does the boiling point of the fluid goes down......which could cause fade or even failure if it boils. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 26, 2006 Share Posted October 26, 2006 I changed the clutch fluid in my 00 Maxima when it was 4 years old. I had never even opened the cap (first owner, ordered from factory) and I was very surprised at the amount of junk in there. I will change the fluid in my LGT every 2 years. Brake fluid every year. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
kosugesan Posted July 30, 2014 Share Posted July 30, 2014 I just switched my brake fluid last week to ATE dot4 fluid. Is it too late to do the clutch fluid now that i've already done the brakes? should i be using the same dot4 fluid i used for my brakes for the clutch fluid? Thanks! Link to comment Share on other sites More sharing options...
AZP Installs Posted August 3, 2014 Share Posted August 3, 2014 The clutch uses the same fluid DOT4 as the brakes. Never a bad thing to do at regular intervals. I would do clutch fluid at every 60k miles whereas the brake fluid is every 30k miles. As for PS fluid, we drain and fill the reservoir every 30k miles with Redline Synthetic PS Fluid which removes about ⅓ of the fluid. -Mike Paisan http://www.pbase.com/paisan/image/153798190.jpg Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
