mevanvt Posted September 25, 2006 Share Posted September 25, 2006 I was wondering if the cleansweep signal was clean from 0-100 on it's volume control or if it would clip past 75% like many AM headunits do. Has anyone scoped it to see if it clips? I tried searching and didn't find any info on this. Manville or anyone could you please answer this b/c i'm getting cdt hd-63s (560i crossovers) and a nine.4 amp to power them and want to set the gains to about 150 watts with a dmm. I'd like to set the gains at 100% volume on the cleansweep so I dont' accidently clip the signal going to the amp. Thanks Link to comment Share on other sites More sharing options...
msmith Posted September 26, 2006 Share Posted September 26, 2006 The CS outputs will not clip, but you should still set your amp gains at 75% CS volume rotation. You want to have a little headroom to turn it up louder when the recording is quiet... it won't be loud enough if you set the amp gains at full CS volume. You can try it if you don't believe me. Best regards, Manville Smith. Link to comment Share on other sites More sharing options...
PGT Posted September 26, 2006 Share Posted September 26, 2006 some older CD's are at a much lower level. You'll need some headroom for those type recordings. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 26, 2006 Share Posted September 26, 2006 my CS setup makes my ears bleed My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mevanvt Posted September 26, 2006 Author Share Posted September 26, 2006 The CS outputs will not clip, but you should still set your amp gains at 75% CS volume rotation. You want to have a little headroom to turn it up louder when the recording is quiet... it won't be loud enough if you set the amp gains at full CS volume. You can try it if you don't believe me. Best regards, Manville Smith. Thanks, I didn't even think about that. I was just worried about clipping the amp so it never crossed my mind. I doubt i'll even have it any where near 100% anyway because I don't listen to music all that loudly. Link to comment Share on other sites More sharing options...
