ipd sways
garvin
Anyone with experience with the rallitech/ipd sways? $200 on sale. Not as thick as the cuscos or cobbs. The bars are going on the Pie's daily driver so I am thinking that it may be a decent compromise for her saftey and my pleasure. I have researched and heard from IPD and they seem to be somewhat of the father of the sway bar. But I have only found one person who has put them on a suby and he had major problems but his was lowered to the extreme which I will not do.
22mm front
19mm rear
Any insight?
Sizes look good if you're running coilovers...as in, you don't need a lot of bar to make the car flatter since you are already running stiffer springs.
I have an IPD 22mm in the rear, coupled with the stock 19mm in the front, but that's for the older BE; is the rear for the BL adjustable or is that only the imprezas'?
They istalled perfect and helped out the cornering alot.
I am happy with them. Taking the machine out to Road America Friday to run it thru the paces. I will let you know how much better it handles after the new mods.
ss brake lines
endless ss-m pads
super blue fluids
motegi ff7 rims
pirelli nero zero m+s
added to invidia up
cobb catted down
tdc 93 oct stage II
