20lgt06 Posted September 19, 2006 Share Posted September 19, 2006 i have an 07 lgt and i installed my old rims from my wrx with 225-45r17's im getting a low tire pressure light on my dash, anyone with this issue before i put back the stockers ? Link to comment Share on other sites More sharing options...
Opie Posted September 19, 2006 Share Posted September 19, 2006 The tire pressure sensor is in the OEM wheel, it's part of the valve stem. You either need to reinstall the OEM wheels in the same spot they came off or see if the sensor can be mounted on your aftermarket wheels and then have it reprogrammed for the car. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 19, 2006 Share Posted September 19, 2006 or you could have the TPMS turned off My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 19, 2006 Share Posted September 19, 2006 Does the 2007 TPMS use a transmitter inside the wheel? You should probably be able to buy an extra set of sensors. When your tires go bald, have the new tires mounted with them. In the meantime,... what mwiener2 said... I like that type of system and am probably going to get an aftermarket system for the minivan. Link to comment Share on other sites More sharing options...
20lgt06 Posted September 20, 2006 Author Share Posted September 20, 2006 i am going to check if the sensor is in the valve stem-- if it is i will see how much it will cost for a spare set to install on the new rims. otherwise since the flashing light is ticking me off im going to put back the stockers thanks for the reply Link to comment Share on other sites More sharing options...
mwiener2 Posted September 20, 2006 Share Posted September 20, 2006 They are in the stems. You need to have the tire off the rim to install them My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Repsak Posted September 20, 2006 Share Posted September 20, 2006 mounting and balancing is about 15 a wheel so think anywhere from 40-60 to change them back depending where you go. Link to comment Share on other sites More sharing options...
red beast Posted September 22, 2006 Share Posted September 22, 2006 sensors are about $80 a piece Link to comment Share on other sites More sharing options...
pillboy Posted September 22, 2006 Share Posted September 22, 2006 Just put the old wheels in back so they can talk to the car and everybody's happy. It is still ugly. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted September 22, 2006 Share Posted September 22, 2006 sensors are about $80 a piece What's the p/n? Link to comment Share on other sites More sharing options...
Spinjockey Posted September 22, 2006 Share Posted September 22, 2006 Just put the old wheels in back so they can talk to the car and everybody's happy. The sensor is activated after the car goes above 15 or so to save battery life so you'd have to bolt them on the side of your new wheels or put them on a teadmill in the back! Link to comment Share on other sites More sharing options...
mwiener2 Posted September 22, 2006 Share Posted September 22, 2006 or you could have the TPMS turned off My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Repsak Posted September 22, 2006 Share Posted September 22, 2006 for infiniti's i know our TPS's are about 200-300 a piece Link to comment Share on other sites More sharing options...
