peterhendy Posted March 17, 2008 Share Posted March 17, 2008 I've noticed that with the non-Homelink compass/mirror the compass defaults to ON each time you turn the car on. Since in my case the car has nav as well as the mirror, anyone know any way to change the default settings to leave the compass off unless I ask for it? Link to comment Share on other sites More sharing options...
CTATV Posted March 23, 2008 Share Posted March 23, 2008 I've noticed that with the non-Homelink compass/mirror the compass defaults to ON each time you turn the car on. Since in my case the car has nav as well as the mirror, anyone know any way to change the default settings to leave the compass off unless I ask for it? good question I too have nav and eventually will be getting an auto dim mirror Link to comment Share on other sites More sharing options...
spect2k Posted June 29, 2008 Share Posted June 29, 2008 is there a writeup somewhere for how to install the homelink mirror? Link to comment Share on other sites More sharing options...
wslm.boarder Posted April 3, 2009 Share Posted April 3, 2009 I have a question about the auto dim mirror, the one I bought has had it's wire cut so I need to know what wires to connect to what, do the colors match?????? I can't believe the junk yard I got this from just cut the wires instead of just unplugging it!!! I guess they didn't know much about Subaru's. Thanks for any input or even a picture, -Jeff- Link to comment Share on other sites More sharing options...
Dust N bones Posted April 13, 2010 Share Posted April 13, 2010 I just purchased a 2009 Legacy Limited today and the mirror is auto dimming with map lights. Has anyone ever seen one of these on a Legacy because I didn't see it mentioned here. It has 2 buttons, one for each light on the left and right sides of the mirror. I'd like to add the Homelink mirror but I wonder if the harnesses will be the same? Link to comment Share on other sites More sharing options...
Brock Samson Posted July 9, 2010 Share Posted July 9, 2010 Just received my Homelink mirror, will be replacing the plain jane version. I bought mine from ebay vendor ByersImports, for $200 shipped. Fast service! don't forget to read the manual on calibrating the compass, etc.... Link to comment Share on other sites More sharing options...
respect23 Posted August 29, 2010 Share Posted August 29, 2010 This is the first upgrade of many on the 06 lgt i just got. Next, VF52 Link to comment Share on other sites More sharing options...
bigdadi Posted August 29, 2010 Share Posted August 29, 2010 The installtion and program the compass instructions are come with the mirror. Use the screw driver to pry the headliner, facing the windshield, a gap then push the wire with a plug at the end thru it. There is a pre-wired socket hidden behind the map lamp assembly. What you is use a small screwdriver to the cover open. Use a small piece electric tape to cover the tip of screwdriver thus no scratching the plastic. Link to comment Share on other sites More sharing options...
05LegacyGt09 Posted October 20, 2011 Share Posted October 20, 2011 Man, first time installing something by myself and it took me 20 minutes. Couldn't figure out where the wire was, it was hidden and wrap up to the right of dome lights inside. Then a little trouble taking off original rear view mirror, needed Allen key too unscrew the screw off on the window, then a peace of cake. Thank you. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted October 21, 2011 Share Posted October 21, 2011 Is there any chance the harness for the mirror is available separately? I want to hardwire my V1 up there, but don't want to splice things. Link to comment Share on other sites More sharing options...
birmy Posted December 1, 2011 Share Posted December 1, 2011 Is there any chance the harness for the mirror is available separately? I want to hardwire my V1 up there, but don't want to splice things. This is how I wired my Valentine to the fuse box, just another idea. http://www.accessafuse.com/access.htm Link to comment Share on other sites More sharing options...
Chubien Posted December 1, 2011 Share Posted December 1, 2011 Is there any chance the harness for the mirror is available separately? I want to hardwire my V1 up there, but don't want to splice things. Yes it is available separately, I had to purchase one after I realized my car was missing the wire that should have been under the dome lights. Link to comment Share on other sites More sharing options...
25gtrbo Posted April 3, 2013 Share Posted April 3, 2013 I have a question about the auto dim mirror, the one I bought has had it's wire cut so I need to know what wires to connect to what, do the colors match?????? I can't believe the junk yard I got this from just cut the wires instead of just unplugging it!!! I guess they didn't know much about Subaru's. Thanks for any input or even a picture, -Jeff- can anyone answer this? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 31, 2014 Share Posted October 31, 2014 Stupid question.. I installed a Gentex auto dim mirror of my '97 Legacy including the out door temp sensor.. the mirror came off I think it was a 2005 tahoe will it be a direct fit or not? Link to comment Share on other sites More sharing options...
