stephenahood Posted July 29, 2006 Share Posted July 29, 2006 Is there a fix out for the dash ILL.5 flicker?? Link to comment Share on other sites More sharing options...
TRS Posted July 29, 2006 Share Posted July 29, 2006 Roll the dash illimination adjuster quickly up and down through its entire range several times to clean the contacts. It's also replaceable under warranty. Link to comment Share on other sites More sharing options...
ShockerGT Posted July 30, 2006 Share Posted July 30, 2006 I used to get the ILL.5/ILL.6 error. It only happened on the ILL.6 setting. I set it down to ILL.5 and now I don't get them anymore. Link to comment Share on other sites More sharing options...
stephenahood Posted July 30, 2006 Author Share Posted July 30, 2006 The 5 setting stopped the problem for a few months, but now it happens there also... Link to comment Share on other sites More sharing options...
pillboy Posted July 30, 2006 Share Posted July 30, 2006 I am assuming it is a contact problem? How about a little aerosol electrical contact cleaner? Radio Shack or the electrical department at a home improvement store. It is still ugly. Link to comment Share on other sites More sharing options...
eb50 Posted July 30, 2006 Share Posted July 30, 2006 wow i had no idea other people had this problem.. it was wicked bad last nite. i will try flipping through them Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted July 30, 2006 Share Posted July 30, 2006 Ill6>ill5 Link to comment Share on other sites More sharing options...
ADirtyLegacy Posted July 31, 2006 Share Posted July 31, 2006 i know i know , but where the hell is the adjuster switch?!?!?! i can't find it and it's driving me nucking futs!!! Kenda Link to comment Share on other sites More sharing options...
TSiWRX Posted July 31, 2006 Share Posted July 31, 2006 ^ On the '05s, it's on the driver's side, by your left knee. It's the same place as the outside mirror adjusters and wiper heater switch. It's a vertical dial. Although most likely such flickering is a contact issue, there's been at least one member here who actually had to get his ECU reflashed/replaced in order to fix this problem. And yes, he's a well-trusted/known LGT-brother, and no, it couldn't be solved any other way. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Scotty Posted July 31, 2006 Share Posted July 31, 2006 Holy crap, how do you guys deal with the dash that bright? I have it on 1 and some times I wish there was a 0.5 setting. Link to comment Share on other sites More sharing options...
eb50 Posted July 31, 2006 Share Posted July 31, 2006 does anyones HVAC and Stereo illumination flicker? I have that problem. No rhyme or reason, and ILL5 and ILL6 display does not flicker Link to comment Share on other sites More sharing options...
Opie Posted July 31, 2006 Share Posted July 31, 2006 I used to get the ILL.5/ILL.6 error. It only happened on the ILL.6 setting. I set it down to ILL.5 and now I don't get them anymore. +1 FTW Link to comment Share on other sites More sharing options...
ADirtyLegacy Posted July 31, 2006 Share Posted July 31, 2006 does anyones HVAC and Stereo illumination flicker? I have that problem. No rhyme or reason, and ILL5 and ILL6 display does not flicker yeah ive had that one too. also had the radio volume randomly go up and down while the controls were flickering. ill attack the dimmer switch when i get back in town. Kenda:dm: Link to comment Share on other sites More sharing options...
TRS Posted July 31, 2006 Share Posted July 31, 2006 does anyones HVAC and Stereo illumination flicker? I have that problem. No rhyme or reason, and ILL5 and ILL6 display does not flickerI have... Link to comment Share on other sites More sharing options...
gfxdave99 Posted July 31, 2006 Share Posted July 31, 2006 I havent and i leave mine on ill.6 most of the time (flicker) but i have had the flashing and on mine its happened maybe 3 times since ive had the car and turning it all the way down and back up a few times and then setting it back to whatever I had it set at seems to stop it. However if that doesnt work and you keep getting the flickering all the time I would have them replace the switch. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
mechdiff Posted July 31, 2006 Share Posted July 31, 2006 I will have to try this. I recently experienced the volume changing on my stereo that everyone was talking about now I have to experience the flicker. I usually have mine on ILL 3 and it is plenty bright. I will have to try this for the sake of experimenting. Link to comment Share on other sites More sharing options...
derffred Posted August 5, 2006 Share Posted August 5, 2006 does anyones HVAC and Stereo illumination flicker? I have that problem. No rhyme or reason, and ILL5 and ILL6 display does not flicker mine doesn't flicker, the complete A/C and radio display just turns off... ;\ happened for the first time last week, then again yesterday morning, then again just now on my way home... i made an appointment for monday to have it fixed... anyone else have this problem? the red lights work and the radio and A/C function completely normal.. just the white lettering disappears.. so both displays are completely black Link to comment Share on other sites More sharing options...
c-lo Posted August 5, 2006 Share Posted August 5, 2006 Is there a fix out for the dash ILL.5 flicker?? if all else fails do the arthurfonzerali method...... a quick 2 hits to the dash. that'll take care of it. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Elec Posted August 6, 2006 Share Posted August 6, 2006 Yep, I get the ILL5/ILL6 flicker too probably a couple times a week. It's annoying. I'll have them look at that along with the driver's side window switch (it kinda sticks and is tough to push to the auto-down depth compared to the other switches) next time I have the car in for service. May be a humidity issue, I'm not sure. I think the radio volume thing happened once. Link to comment Share on other sites More sharing options...
derffred Posted August 6, 2006 Share Posted August 6, 2006 . I'll have them look at that along with the driver's side window switch (it kinda sticks and is tough to push to the auto-down depth compared to the other switches). my car is goin in tomorrow for the window switches binding and the radio display turning off... you think they'll warranty it? my car is still covered.. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 6, 2006 Share Posted August 6, 2006 if all else fails do the arthurfonzerali method...... a quick 2 hits to the dash. that'll take care of it. Link to comment Share on other sites More sharing options...
