MIKEBRAVO Posted July 19, 2006 Share Posted July 19, 2006 I have heard that in the past the heat shield welds on the Sti uppipes have broken loose and rattled. As a result, I decided to have some welds added, six to be exact. Prior to the new welds you could hear the shield's propensity to rattle by just taping on it. The original welds where weak and too few. I had to be careful though, I didn't want to added too many and mess with the expansion and contraction feature. I am happy with what I ended up with. If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
wcbjr Posted July 19, 2006 Share Posted July 19, 2006 Nice. Wish I knew how to weld. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
HansGT Posted July 19, 2006 Share Posted July 19, 2006 great job...want to sell it? Link to comment Share on other sites More sharing options...
hal9e3 Posted July 19, 2006 Share Posted July 19, 2006 How much did it cost you? Link to comment Share on other sites More sharing options...
Boostjunkie Posted July 19, 2006 Share Posted July 19, 2006 Problem is that you didn't reinforce the welds that actually break. The problematic areas are where the heat shields attach to the flanges. That's were you want to add a few spot welds. I bought a used STi uppipe a while ago and those are the welds that failed. Took it to a muffler shop and they welded it up for me. When I asked how much I owed them, the owner said just tip the welder. I think I gave him $10. Link to comment Share on other sites More sharing options...
HansGT Posted July 19, 2006 Share Posted July 19, 2006 Problem is that you didn't reinforce the welds that actually break. The problematic areas are where the heat shields attach to the flanges. That's were you want to add a few spot welds. I bought a used STi uppipe a while ago and those are the welds that failed. Took it to a muffler shop and they welded it up for me. When I asked how much I owed them, the owner said just tip the welder. I think I gave him $10. would you mind highlighting those areas described on the images in this thread? Link to comment Share on other sites More sharing options...
wcbjr Posted July 19, 2006 Share Posted July 19, 2006 I bought a used STi uppipe a while ago and those are the welds that failed. Took it to a muffler shop and they welded it up for me. When I asked how much I owed them, the owner said just tip the welder. I think I gave him $10. I took my 240's header to a shop to weld up the emissions crap, he said the same thing. Just tip the welder. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted July 19, 2006 Author Share Posted July 19, 2006 would you mind highlighting those areas described on the images in this thread? Its the weld next to the Subaru insignia. I thought about adding another weld on the flange but its Stainless, which is part of the prob, because the shield isn't. The difference in metals contributes to the weakness. Additionally the shield is attached to the flange via a tab from the heatshield. I'm not sure if adding additional welds would help. In fact it might even affect the expasion and contraction aspects of the metal. However, I think vibration is the true problem, so in hopes of limiting the vibration of the two shield pieces rubbing I had those secured. If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
lucas569 Posted July 20, 2006 Share Posted July 20, 2006 i went to nasioc forum to look for one with no luck, im wondering which aftermarket ones have no problems? i read about some leaking here and there, my plans are to get the up and the dp. the ones the catch my intirest the most are the cobb units, they look well built. Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted July 20, 2006 Author Share Posted July 20, 2006 i went to nasioc forum to look for one with no luck, im wondering which aftermarket ones have no problems? i read about some leaking here and there, my plans are to get the up and the dp. the ones the catch my intirest the most are the cobb units, they look well built. Was the leaking from the gaskets or flex joint? If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
lucas569 Posted July 20, 2006 Share Posted July 20, 2006 i mostly have read of ones leaking at the gasket.... Link to comment Share on other sites More sharing options...
Rommel Posted July 20, 2006 Share Posted July 20, 2006 just need to get a flex up pipe to avoid the leaks Link to comment Share on other sites More sharing options...
jagcars26 Posted July 20, 2006 Share Posted July 20, 2006 Isnt a new one(STi catless) from the dealer rather reasonable?? I'm thinken under $150 ?? maybe I'm wrong. Link to comment Share on other sites More sharing options...
scoobydrew Posted July 20, 2006 Share Posted July 20, 2006 Isnt a new one(STi catless) from the dealer rather reasonable?? I'm thinken under $150 ?? maybe I'm wrong. I just got a "deal" on one, $297. Flex and heat shield were important. No one had the nearly indentical Bosal for $169, in stock. ProTUNED by RaminiSports Link to comment Share on other sites More sharing options...
HansGT Posted July 20, 2006 Share Posted July 20, 2006 I just got a "deal" on one, $297. Flex and heat shield were important. No one had the nearly indentical Bosal for $169, in stock. STI OEM = Bosal Link to comment Share on other sites More sharing options...
HansGT Posted July 20, 2006 Share Posted July 20, 2006 just need to get a flex up pipe to avoid the leaks yes, a flex allows for easier fitment, but I thought flex's could end up leaking over time at the "flex" section as this area is prone to more wear??? i think it really comes down to the installer and if they are tightening everything up properly (flex or not). i think a lot of the leaks reported are because of shade tree machanics or shops that don't take the time to do it right or think they are doing it right, but aren't. my 2 cents. Link to comment Share on other sites More sharing options...
lucas569 Posted July 20, 2006 Share Posted July 20, 2006 I just got a "deal" on one, $297. Flex and heat shield were important. No one had the nearly indentical Bosal for $169, in stock. the bosal costs that much!? thats a good price, might have to look at that one.... Link to comment Share on other sites More sharing options...
