PGT Posted July 18, 2006 Author Share Posted July 18, 2006 well....several fuses and horn chirps later, I'm tackling the relays on this, the hottest day of summer so far. Look about right?? http://www.rallylights.com/useful_info/useful_images/horns.gif I've got a pair of new 20A relays (four pole) plus some older 30A Bosch relays. I also picked up some 14wg and two fuse holders. Do I need to wire each horn independently (one relay per horn), or can I cheat and do one relay triggering both? Link to comment Share on other sites More sharing options...
PGT Posted July 18, 2006 Author Share Posted July 18, 2006 everyone's a critic but nobody wants to help, eh? Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted July 18, 2006 Share Posted July 18, 2006 I would if I could, but I can't, sooooooo............................ YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
Guest Posted July 18, 2006 Share Posted July 18, 2006 Do the math, LGT. Stebel Nautilus draws 18 Amps. So one per relay. For two you need like ~40Amp relay, but then you need 40 Amp rated fuse holder. All I 've seen at local stores are 30 Amp max for some reason. I wired two Magnum horns (12A each), I am adding one Nautilus, so I'll end up with two relays setup. Link to comment Share on other sites More sharing options...
Guest Posted July 18, 2006 Share Posted July 18, 2006 Also, advantage of two relays is redundancy. If one fails, one horn will work. Of course the factory relay is the single point of failure... Link to comment Share on other sites More sharing options...
Guest Posted July 18, 2006 Share Posted July 18, 2006 The diagaram looks ok (if you had 40A relay). Link to comment Share on other sites More sharing options...
PGT Posted July 18, 2006 Author Share Posted July 18, 2006 meh....rated load with electronics isn't as simple as A+B. Link to comment Share on other sites More sharing options...
Guest Posted July 18, 2006 Share Posted July 18, 2006 Alright, electricity was not my strong point... somehow 2x18A on single 20A relay does not seem probable... Link to comment Share on other sites More sharing options...
PGT Posted July 18, 2006 Author Share Posted July 18, 2006 agreed, but I have a pair of 30A as well, thus my Q. 2x18A might work fine on a single. I'm going to wire up both....I like your suggestion of some redundancy, besides they might be louder with independent power sources. Link to comment Share on other sites More sharing options...
red beast Posted July 20, 2006 Share Posted July 20, 2006 go up on your deck and look at her Link to comment Share on other sites More sharing options...
PGT Posted July 21, 2006 Author Share Posted July 21, 2006 Link to comment Share on other sites More sharing options...
