mwiener2 Posted May 28, 2010 Share Posted May 28, 2010 i guess you could replace the condenser itself, but you can't recharge it yourself My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
TonyD Posted May 28, 2010 Share Posted May 28, 2010 i guess you could replace the condenser itself, but you can't recharge it yourself Yeah, that's what I was thinking at the very least.. I think to charge it up you have to be licenced and also a scientist. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 29, 2010 Share Posted May 29, 2010 You need a vacuum pump to evacuate the system. You need dry nitrogen to purge the system. The actual refrigerant any joe schmoe can buy at the parts store... oddly enough. I have my universal refrigeration license. Automotive is a separate license. I am able to work on a gigantic low pressure chiller that has thousands of pounds of refrigerant in it, usually a refrigerant with a high "bad for the environment" rating. But, I'm not allowed to touch a car which has 10lbs max in it and uses R-134a. The same thing used in computer duster cans. Near zero "bad for the environment" ratings. Don't ask me what genius at the EPA came up with that system. Probly more to keep auto guys from working on the other stuff rather than the other way around. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
