victorx Posted June 17, 2006 Share Posted June 17, 2006 Is it a popular problem on 2.5 H4 (turbo or non-turbo)? I have heard quite a few complains about Head Gasket leak of those engines, and it will cost a lot to fix it. Am I misleaded? Thanks Link to comment Share on other sites More sharing options...
spillNUTZ Posted June 17, 2006 Share Posted June 17, 2006 I'm not sure if its common. but i had the same problem with mine. But i was fortunate. The previous owner had it repaired at the dealership. So when it busted again, it was warranty work for me. Link to comment Share on other sites More sharing options...
FONTANA MOTORSPORTS Posted June 17, 2006 Share Posted June 17, 2006 98-99 2.5 twincams had the head gasket failures all the time....some even damaged the blocks.the newer 2.5 turbo motors are much more stout in the head gasket areas Link to comment Share on other sites More sharing options...
Scotty Posted June 17, 2006 Share Posted June 17, 2006 I was talking to a friend of mine who was a mechanic. He said the older Scooby did have a head gasket problem. It always occured with the #3 cylinder if I remember correctly. He said one of the common problems was power loss. Once that started occuring, it's always the #3 cylinder's gasket. He hasn't seen any problems with the new Scoobs. Link to comment Share on other sites More sharing options...
Garandman Posted June 17, 2006 Share Posted June 17, 2006 It's primarily 95-99 "Phase I" DOHC 2.5 [non-turbo] engines as in the Outback during that period. Early symptoms are sudden temporary temp spikes and combustion byproducts or bubbling in the coolant overflow tank. The job is around $1,200 at a garage if you didn't fry the motor. I had mine changed at 140K pre-emptively. Still going strong at 175K. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 18, 2006 Share Posted June 18, 2006 My bro's '01 RS had a recall for a conditioner for this problem. However, head gaskets failure only occurs in 9% or so I think it is. Not terrible, but not great either. Link to comment Share on other sites More sharing options...
crafty Posted June 19, 2006 Share Posted June 19, 2006 9% is a lot in my book and I am sure 9% is watered down besides Link to comment Share on other sites More sharing options...
snoman Posted June 19, 2006 Share Posted June 19, 2006 My mom's 2002 Legacy and my friend's 2002 Legacy both had headgasket failures with under 40,000 miles on the clock. The symptoms included "gushing water" sounds when starting the car in the morning, and a faint burning smell at stop lights. Link to comment Share on other sites More sharing options...
camber Posted June 19, 2006 Share Posted June 19, 2006 My mom's 2002 Legacy and my friend's 2002 Legacy both had headgasket failures with under 40,000 miles on the clock. The symptoms included "gushing water" sounds when starting the car in the morning, and a faint burning smell at stop lights. The "gushing water" sound is just air in the heating core. It's pretty common sound in subbies. However, I guess if you lost enough coolant through the HGs that would cause air to get in the system and cause a "gushing water" sound. Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 19, 2006 Share Posted June 19, 2006 9% is a lot in my book and I am sure 9% is watered down besides Thats Subaru for you. Reputation of high quality my ass....or at least their more current stuff is crappy. I only had one problem with my '96. Ruptured cam seal. $200. Not a big deal. As much as I rag on Honda/Acura for having crappy, rusty cars, my Prelude had very few mechanical problems. Link to comment Share on other sites More sharing options...
SLegacy99 Posted June 19, 2006 Share Posted June 19, 2006 The "gushing water" sound is just air in the heating core. It's pretty common sound in subbies. However, I guess if you lost enough coolant through the HGs that would cause air to get in the system and cause a "gushing water" sound. Talk about power loss. Link to comment Share on other sites More sharing options...
