Johan Posted June 15, 2006 Author Share Posted June 15, 2006 Almost have everything I need for stage II..(I will be doing Downpipe and Uppipe) I just want to make sure I have all the gaskets I need. I was told I only need DP to turbo, UP to turbo, manifold to UP. Is this correct or will I need anything else? Link to comment Share on other sites More sharing options...
TSiWRX Posted June 15, 2006 Share Posted June 15, 2006 If you're taking apart the manifolds themselves (i.e. dropping the manifolds from both sides of the engine), some will also recommend new block-to-manifold gaskets. If you're taking apart the passenger's side manifold -to- cross-pipe (an alternative to the above, here, only the passenger's side manifold is dropped from the vehicle), some will recommend a new gasket in that area. Re-using your original gaskets in these areas is possible, provided that they are in good-shape. This becomes an issue of "personal recommendations." <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
wukindada Posted June 15, 2006 Share Posted June 15, 2006 As far as power handling with the 5AT.....my car shifts MUCH smoother now than it did when stock:) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
