skibud2 Posted September 9, 2004 Share Posted September 9, 2004 Let's get a list of all the little features that people don't notice before they buy the car. So far this is what I have found: (Note: I have a GT limited 5EAT) 1) Press the remote lock button on the key three times and the car beeps to help indicate its location. 2) Is it just me, or does the defogger sometimes turn on when the car is started (maybe some sensing -- don't know). 3) (more obvious, but I will list is anyway) windshield wiper heaters. 4) 5EAT owners -- you can shift using the stearing wheel shifters when you are in regular drive mode. 5) If you want to deactive the moving gauges on the GT models, there are instructions in the owners manual. 6) 5EAT owners -- the computer limits the maximum shift RPM until it believes everything is broken in. 7) (Also may be obvious) On the 5EAT trans, in sport mode, if you don't shift manually, the transmission will shift automatically but more agressivly than in regular drive mode. Link to comment Share on other sites More sharing options...
GardenWeasel Posted September 9, 2004 Share Posted September 9, 2004 If you leave the keys in the ignition, you can't lock yourself out. :P Link to comment Share on other sites More sharing options...
llmask Posted September 9, 2004 Share Posted September 9, 2004 thnx! Link to comment Share on other sites More sharing options...
NewSubieLegacy Posted September 9, 2004 Share Posted September 9, 2004 If you have a door open, then press the lock button on the fob - it beeps 5 times, then when you close the door it automatically locks. (don't leave the keys inside) The passenger can unlock all the doors. Link to comment Share on other sites More sharing options...
c_hunter Posted September 9, 2004 Share Posted September 9, 2004 Note sure these are that insightful -- most of these features were discussed on Edmunds.com Subaru forums before the cars were even available! Re: #2, when the outside temperature is lower than the "set" temperature, the system defaults to defrost and the blower turns off until the engine coolant is warm enough to heat the interior. That way the system is not blowing cool air. My 02 LL Bean did the same thing. Craig Link to comment Share on other sites More sharing options...
Stef Posted September 9, 2004 Share Posted September 9, 2004 They may be posted or discussed elsewhere, but still new to a lot of people, I'm sure. Thanks for the helpful info, makes me look forward to getting the car all the more!! (Now I really want to know what happens if you leave the keys in the ignition AND push the lock button on the FOB) :D Link to comment Share on other sites More sharing options...
Drift Monkey Posted September 9, 2004 Share Posted September 9, 2004 [quote name='GardenWeasel']If you leave the keys in the ignition, you can't lock yourself out. :P[/quote] I have, keyfob and all. Had to get my spare upstairs! :lol: :oops: Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted September 9, 2004 Share Posted September 9, 2004 [quote name='GardenWeasel']If you leave the keys in the ignition, you can't lock yourself out. :P[/quote] Slimjim and/or brick. Either way I'm gettin in.... :D OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
DAP Posted September 9, 2004 Share Posted September 9, 2004 There is no keyhole in the trunk (sedan). You can lock the trunk with the key (on the interior release), but this does not lock the pass through. You can not set the heater temperature separately from the air conditioning. You can not turn the heat off and set the air condititioning temperature high. (I'd really like a programmable dead zone between the heat comming on and the AC comming on, say turn the heat on below 70, and the AC on above 75). All the lettering on the trunk is easily removed :) Link to comment Share on other sites More sharing options...
Legacy05GT Posted September 9, 2004 Share Posted September 9, 2004 The dual cup holders in the backseat with collapsable arms to fit all sizes of b33r bottles. The trunk opener on the inside of the trunk hatch for when the duct taped hooker needs some air. The small storage flap above the stereo with the ugly orange light inside of it. Link to comment Share on other sites More sharing options...
Xaqtly Posted September 9, 2004 Share Posted September 9, 2004 If the alarm is set and you open the trunk using the keyfob, when you close the trunk it will beep and re-arm itself. Link to comment Share on other sites More sharing options...
inthedeck Posted September 9, 2004 Share Posted September 9, 2004 Press the trip meter reset button once when the car is off, and the gas gauge needle will light up. Also, there is no key hole in the front passenger door in the sedan -- make sure your batteries work!!! later, i. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 9, 2004 Share Posted September 9, 2004 What would be the trunk button on the keyfob only unlocks the wagon hatch- doesn't actually open it. Link to comment Share on other sites More sharing options...
Ken S Posted September 10, 2004 Share Posted September 10, 2004 [quote name='skibud2']Let's get a list of all the little features that people don't notice before they buy the car. So far this is what I have found: (Note: I have a GT limited 5EAT) 1) Press the remote lock button on the key three times and the car beeps to help indicate its location. 2) Is it just me, or does the defogger sometimes turn on when the car is started (maybe some sensing -- don't know). 3) (more obvious, but I will list is anyway) windshield wiper heaters. 4) 5EAT owners -- you can shift using the stearing wheel shifters when you are in regular drive mode. 5) If you want to deactive the moving gauges on the GT models, there are instructions in the owners manual. 6) 5EAT owners -- the computer limits the maximum shift RPM until it believes everything is broken in. 7) (Also may be obvious) On the 5EAT trans, in sport mode, if you don't shift manually, the transmission will shift automatically but more agressivly than in regular drive mode.[/quote] Where did you hear about #6? Do you mean "warmed up" vs. "broken in"? Ken Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 10, 2004 Share Posted September 10, 2004 If you press the "Disp" button with the car off, it shows you the time. Link to comment Share on other sites More sharing options...
red beast Posted September 10, 2004 Share Posted September 10, 2004 if you get 2 s-hooks and 2 forester side nets, they will fit in your trunk. my car + dual side nets = 100 more hp :D Link to comment Share on other sites More sharing options...
c_hunter Posted September 11, 2004 Share Posted September 11, 2004 [i] Where did you hear about #6? Do you mean "warmed up" vs. "broken in"? Ken [/i] -- Hey Ken, This might be getting confused with the feature where the AT delays upshifts in order to warm up the transmission. For instance, if you start off on a cold morning it will hold 2nd and/or 3rd gear, delaying upshift, until the tranny warms up. I don't think the car senses break-in. On one of my test drives, a bonehead car salesman had no problem redlining a GT wagon with only 12 miles on the clock..... Craig Link to comment Share on other sites More sharing options...
skibud2 Posted September 11, 2004 Author Share Posted September 11, 2004 Hey I might be imagining this, but I noticed that I got much better gas milage with 91 octane over 93 octane. With the 93, I was getting around 18.5 mpg. I put the 91 in, and I started getting 23. I recently put 91 back in and the mpg average dropped again. Does this make sense? Also, how long of an average does the computer use to make its calculations? Link to comment Share on other sites More sharing options...
NewGTGuy Posted September 11, 2004 Share Posted September 11, 2004 Here is one: When the gas light comes on, the red outline on the gas gauge blinks and the temp display changes to "distance to empty" for a couple of seconds. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 12, 2004 Share Posted September 12, 2004 [quote name='NewGTGuy']Here is one: When the gas light comes on, the red outline on the gas gauge blinks and the temp display changes to "distance to empty" for a couple of seconds.[/quote] That's neat- I'll hafta run my tank a little closer to empty next time. Does anyone know if the tank in the Legacy has baffles so you don't suck up crud from the bottom of the tank, like in the WRX? Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted September 12, 2004 Share Posted September 12, 2004 [quote name='jedimaster']That's neat- I'll hafta run my tank a little closer to empty next time. Does anyone know if the tank in the Legacy has baffles so you don't suck up crud from the bottom of the tank, like in the WRX?[/quote] Is that the case that the WRX sucks up crud, or the WRX has baffles? Just curious, because if the WRX has baffles, the Legacy probably does too, if the wrx doesn't, the legacy is anybody's guess. Operating on the principle that the legacy is more expensive, and therefore should have the features that are common to less expensive cars from the same company. Plus the off-road capabilities of the outback should dictate that the tank is baffled. Hate to have the pump suck dry on an off-road incline, if the tank happens to be a little low. Link to comment Share on other sites More sharing options...
fan42025 Posted September 12, 2004 Share Posted September 12, 2004 What about the cool seat belt indictators near the map lights above? Green ones come on if used in the rear, red one for the front passenger if not used. Some passengers make the comment they feel they are in a plane when they see these. Link to comment Share on other sites More sharing options...
sduford Posted November 20, 2004 Share Posted November 20, 2004 When you pull the hand brake, the daytime running lights turn off. Sylvain www.digitalfotographer.com - Audi Q5 Club - MB-GLK Club Link to comment Share on other sites More sharing options...
