mthurmond Posted May 18, 2006 Share Posted May 18, 2006 Have you ever tuned a car that is using a J&S Safeguard? If so, what are your thoughts. On an STI swap, (STI UPPipe, Turbo, TMIC, Intake) is there any safety risk to running the factory downpipe? If not, do you have a canned map for that setup? Link to comment Share on other sites More sharing options...
rao Posted May 18, 2006 Share Posted May 18, 2006 IMHO, there would be no benefit to the Safegaurd over the stock knock detection and control system. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mthurmond Posted May 18, 2006 Author Share Posted May 18, 2006 The benefits I've heard are: Knock correction on a per cylinder basis, and quicker detection and correction. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 18, 2006 Share Posted May 18, 2006 IMHO, there would be no benefit to the Safegaurd over the stock knock detection and control system. they would not sell any units if this were true. Every car has knock detection, its how the car reacts that is key.... which is where the Safegaurd comes in. BUT... with proper tuning you should be safe (assuming you don't mess with anything after the tune). Link to comment Share on other sites More sharing options...
TDC Tuning Posted May 18, 2006 Share Posted May 18, 2006 the factory ecu is smarter than the safegaurd and does the same thing TDC Tunings LGT Forum Cobb, Perrin, APS, Invidia, Megan racing and MORE!! Your #1 source For Subaru / Legacy GT performance parts! Link to comment Share on other sites More sharing options...
CasopoliS Posted May 18, 2006 Share Posted May 18, 2006 the factory ecu is smarter than the safegaurd and does the same thing is that true for all cars? Maybe I am underestimating the subaru ECU. My mazda ECU sucked... maybe why so many engines blew at 8psi.... Well that is good to hear, thanks TDC! Link to comment Share on other sites More sharing options...
Deer Killer Posted May 18, 2006 Share Posted May 18, 2006 Subaru thinks their knock sensor is good enough they can use it to compensate for a heatsoaked TMIC, with no idea of how heatsoaked it is. They also explicitly say you may hear audible knock in the owner's manual.*hmmmm* Link to comment Share on other sites More sharing options...
rao Posted May 18, 2006 Share Posted May 18, 2006 People sell fuel magnets as well That product is excellent for cars that do not have knock sensors. The Legacy's ECU can detect knock on a per cylinder basis. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
KGreb Posted May 18, 2006 Share Posted May 18, 2006 Maybe I am underestimating the subaru ECU. My mazda ECU sucked... maybe why so many engines blew at 8psi.... J&S boxes were pretty popular with the turbo miata crowd for a long time, before stand alone ECUs were available. J&S is a good product, but it was intended for adding forced induction to a car with a normally aspirated ECU. A real ECU that understands a forced induction application is a much better solution. Link to comment Share on other sites More sharing options...
