robinlsb Posted May 9, 2006 Share Posted May 9, 2006 Will OEM OBXT wheels and tires fit on an 06 LGT wagon? Going to Labrador this summer and based on the projected road beds (ALL DIRT),I think a more robust set of rims and tires might be in order. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
eb50 Posted May 11, 2006 Share Posted May 11, 2006 Will OEM OBXT wheels and tires fit on an 06 LGT wagon? Going to Labrador this summer and based on the projected road beds (ALL DIRT),I think a more robust set of rims and tires might be in order. obxt is 17x7 48mm offset if that helps at all.. i blieve lgt is 53 off set Link to comment Share on other sites More sharing options...
Boostjunkie Posted May 11, 2006 Share Posted May 11, 2006 The size and offset of the wheels will work just fine, the problem is that the OBXT tires are vastly larger than the tires on the LGT. Aside from looking really goofy, I doubt that they will fit with adaquate clearance in the wheelwells considering the lower ride height of the LGT. Link to comment Share on other sites More sharing options...
ilh Posted May 11, 2006 Share Posted May 11, 2006 i blieve lgt is 53 offset55 Link to comment Share on other sites More sharing options...
