Beanboy Posted May 9, 2006 Share Posted May 9, 2006 I've done it before and it is recommended in the directions, just curious if it is a good idea with two layers of sealant already on the car? Not sure if I will put another layer of sealant on, just want to make sure I won't be removing what's already on the car... -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
wukindada Posted May 9, 2006 Share Posted May 9, 2006 Not an answer for your question Bean.....but I am also looking for a replacement for my NXT car wash. No stores in my area carry it anymore:( I wash the car twice a week & I only have 1 more bottle left! Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
iyalla Posted May 9, 2006 Share Posted May 9, 2006 AIO is a cleaner. It will remove or compromise what you already have on there, especially if your hand pad is a little aggressive. I guess you can layer it but go lightly. For effective layering you need a pure sealant like Klasse SG or Wolfgang gloss. Link to comment Share on other sites More sharing options...
Beanboy Posted May 9, 2006 Author Share Posted May 9, 2006 Not using a hand pad, just terry cloth mit. Washing car with AIO, not applying it. Capful of AIO in 5 gallons of water. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
iyalla Posted May 9, 2006 Share Posted May 9, 2006 I guess thats as light as you can get it. It probably works but its probably not very effective. If you're looking for something quick get the Wolfgang gloss spritz. Spray and wipe thats it no waiting for haze or anything. You'll be done in 15 minutes and you'll get a much more effective layer of sealant on there. Link to comment Share on other sites More sharing options...
Beanboy Posted May 9, 2006 Author Share Posted May 9, 2006 No, I'm talking about washing the car, not applying anything. As in removing layers of dirt and pollen when lots of water and AIO versus a car wash solution. http://www.customacrylic.com/klasse.html "Car wash: Avoid using dishwashing detergent. Its chemicals remain on the finish and begin to oxidize. Substitute a capful of "All-in-One", instead. "All-in-One" won't foam-up, but will lift dirt. Wash car normally." Doesn't say whether or not it will be okay for a car that already has sealant on it if it is used or not. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
eamiller Posted May 9, 2006 Share Posted May 9, 2006 My impression is that they are suggesting using AIO as a surface prep wash instead of Dawn to strip off the old junk. I'm pretty sure AIO is going to remove your extra coats of SG, but if you only use AIO, I don't see the harm in using it frequently in the wash. Link to comment Share on other sites More sharing options...
