Paradiso Posted April 21, 2006 Share Posted April 21, 2006 My son took his 94 legacy wagon to subaru dealer to pull codes. They told him codes were 35 - O2 sensor and 32 - CPC system (??) What's CPC? Is code 35 front or rear O2 sensor? Thanks in advance for any help. John Link to comment Share on other sites More sharing options...
Aczwild Posted April 21, 2006 Share Posted April 21, 2006 The code 32 is the Oxygen Sensor (front I believe) and the code 35 is The Purge control solenoid valve JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
Aczwild Posted April 21, 2006 Share Posted April 21, 2006 Gimmie a bit to find the info on the two (ie; later tonight I'll have the answer or more help) JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
Paradiso Posted April 21, 2006 Author Share Posted April 21, 2006 I owe you a coupla beers! Thanks Link to comment Share on other sites More sharing options...
Aczwild Posted April 21, 2006 Share Posted April 21, 2006 Alrighty, the O2 sensor will have to be replaced because the 32 code is saying that the circuit is open. When I say open, I mean it is stuck in its open loop mode for when the car is cold (after you just started the car for about 2 minutes) where, if you measure the voltage across the signal wire and the ground wire you'll get a steady .1-.2 voltage signal. This should then switch into its closed loop form where the voltage would fluctuate between .1-.9 volts (its kinda cool, at .1 volts its running with a high oxygen, lean mixture and at .9 its running with a low oxygen, rich mixture). Most likely what has happened is either the sensor is remaining in the open loop position, or it is taking a long time to switch into the closed loop mode. You'll have to replace the sensor. ** Tip on O2 sensor removal, drive the car around a bit so the threads on the sensor are warm and not a bitch to unscrew. Granted now you have to be careful not to burn yourself on the exhaust Gimmie a bit more time on the code 35 (Purge control solenoid valve), I' hungry and need to make something to eat JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
Aczwild Posted April 21, 2006 Share Posted April 21, 2006 Ok I dont have much on the code 35, Purge control solenoid valve, except that the probable cause is that the solenoid reamins in the on, or off position when the car is being driven. JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
jerami1981 Posted April 22, 2006 Share Posted April 22, 2006 i have nothing worthwhile to say other than thanks for being a great, helpful person..ps i'm not related to this guy or problem in any way, just a passing stranger Link to comment Share on other sites More sharing options...
Paradiso Posted April 22, 2006 Author Share Posted April 22, 2006 i have nothing worthwhile to say other than thanks for being a great, helpful person. Absolutely! I can't thank you enough. Does the code 32 tell us which O2 sensor (front or rear??) Link to comment Share on other sites More sharing options...
Aczwild Posted April 22, 2006 Share Posted April 22, 2006 Doesnt say which, but do you have access to a voltmeter? My guess would be the one in the cat after the headers, but if you have access to a voltmeter and want to have some fun under the car, then you can test them JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
Aczwild Posted April 22, 2006 Share Posted April 22, 2006 Oh wait I forgot, on 1990-1994 Legacys there is only one Oxygen Sensor located upstream of the catalytic converter, so that be the one captain JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
