mwiener2 Posted January 22, 2010 Share Posted January 22, 2010 You have to be a premium donator. If you are, your privileges got messed up when you got vendor status, PM Tide about it. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Matty2Hotty Posted January 24, 2010 Share Posted January 24, 2010 What about my 01 lgt? Sounds like what I want on my car. Would be nice to know if it works on 00 to 04s. Link to comment Share on other sites More sharing options...
knightgambit Posted January 28, 2010 Share Posted January 28, 2010 I've sold to 2009's that haven't come back, so my guess is the electronics are just the same. There's seems to be a big break for 2010 in body design, not sure of the electronics for the 'now' generation of larger Leggy's.. but maybe the electronics are all the same in that too. Cheers! Scott, Thanks for the info. It seems the only way to buy the tap turn to buy the aux control, so I will have to save up a little more money Coming from an A4 both of these features will make me feel right at home again. Link to comment Share on other sites More sharing options...
scottmcphee Posted March 20, 2011 Author Share Posted March 20, 2011 If you ask me nice I've been known to make just the 'Tap Turn' module itself, as a stand alone... price is negotiable. I must be getting soft in my old age. Scott Link to comment Share on other sites More sharing options...
scottmcphee Posted March 20, 2011 Author Share Posted March 20, 2011 People with WRX's and STi' s and stuff are always asking "does tap turn work in my car"? The answer is no. Subaru does quite a bit different in the Impreza line of cars in the area of electronics. And signals is one of those areas. Impreza uses surprisingly "traditional" (read: old school) methods of flasher control, regulating pulses on the high side (+12V), rather than what Legacy does controlling on the low side (ground). Short answer: Impreza (of any flavour), sorry. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 21, 2011 Share Posted March 21, 2011 Can you make a different one for them? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
scottmcphee Posted August 28, 2011 Author Share Posted August 28, 2011 Some sort of timed relay might work for a tap turn in the pre-2007 Impreza flock. 2007 and up Impreza fits and works fine with TapTurn The trick would be cutting the relay off early if the signal stalk gets flipped to the other direction, before the tap turn time is up. But there are probably timer relays with cut-off inputs for this purpose. Problem is these get expensive, and you'd need two. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 28, 2011 Share Posted August 28, 2011 I would think you could do it with 2 555 chips at a whopping 30 cents each. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Power6 Posted September 27, 2011 Share Posted September 27, 2011 Short answer: Impreza (of any flavour), sorry. Is it possible you were dealing with older model Imprezas? According to all of the Impreza FSMs for the 08+, the wiring is exactly the same for the flasher as the 05+ Legacy. Then head over to opposedforces and see the Subaru part number for the flasher in the Legacy is the same for all 08+ Impreza, 09+ Forester and the Tribeca. Interestingly enough the 05-10 Euro version Legacy doesn't share the same flasher, interesting. Anyways I was just looking for flasher information when using LEDs and happened upon this. I'm the guy who e-mailed you about the Autowindow I have in my 09 WRX, works great! I have a feeling you asked me about the parking light flash for the reason that you thought it was different. I still owe you an e-mail with the wiring stuff, but the parking lights do flash properly when programming the Autowindow features. The 08+ Impreza def uses the same type of flasher. Link to comment Share on other sites More sharing options...
scottmcphee Posted September 27, 2011 Author Share Posted September 27, 2011 People with WRX's and STi' s and stuff are always asking "does tap turn work in my car"? The answer is no. Subaru does quite a bit different in the Impreza line of cars in the area of electronics. And signals is one of those areas. Impreza uses surprisingly "traditional" (read: old school) methods of flasher control, regulating pulses on the high side (+12V), rather than what Legacy does controlling on the low side (ground). Short answer: Impreza (of any flavour), sorry. OK, wow, learned something new every day even if I'm a couple model years behind. Apparently, the 2009 Impreza uses the same flasher unit as described here. Just realized this when somebody reported an AutoWindow install for 09 Impreza is vastly similar to my 06 Legacy. And as somebody pointed out this may have started in MY 2008 for Impreza. SO I retract my statement "any flavour"... it seems Impreza 2008 and up will work with tap turn. Go Subaru! This also means that AutoWindow Universal Fit (see my storefront www.autowindow.com) will work with the newer Impreza's. Customer supplied the specific wiring color charts and installation advice to go with this car. (Thanks Power6!) Link to comment Share on other sites More sharing options...
scottmcphee Posted May 20, 2012 Author Share Posted May 20, 2012 Turns out a lot of Toyota and Lexus use this same (or very similar) Denso flasher, so Tap Turn would work for them too... And I made a video: Link to comment Share on other sites More sharing options...
mwiener2 Posted May 20, 2012 Share Posted May 20, 2012 So this will work on my Yaris too!!??! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
scottmcphee Posted September 7, 2012 Author Share Posted September 7, 2012 So this will work on my Yaris too!!??! yes! Tap Turn II is good for Yaris. Link to comment Share on other sites More sharing options...
13fido13 Posted September 8, 2012 Share Posted September 8, 2012 Where in Canada are you located? Do you accept EMT as well? Link to comment Share on other sites More sharing options...
scottmcphee Posted September 11, 2012 Author Share Posted September 11, 2012 western part, sure can do that PM me Link to comment Share on other sites More sharing options...
scottmcphee Posted July 31, 2013 Author Share Posted July 31, 2013 August 2013 is loyalty month for LegacyGT members who have Tap Turn generation one. It all started here, probably in this thread shortly after getting my car in 2006 when I started playing around with my flasher to get convenience signaling on a car that didn't have it. Several people bought - what I'll now call "generation one" Tap Turn - and hooked it up to their flasher to get the one-touch convenience signaling (3 blinks, not programmable). Its origins are described at the beginning of this thread. I sometimes bundled it with another module called RRAP (retained and resumable accessory power), or came as a little white box with 4 wires that vipered onto 4 flasher lines. Its success and demand prompted me to go further. So I made a new design TapTurn (generation two) which is a whole new game. This is a plug and play replacement flasher that offers a lot more function. I wanted to do a give-back of sorts to early Tap Turn adopters on this forum... to those who bought generation one: I'm offering a special deal in the month of August 2013 to get the new version out to any member of LegacyGT who bought generation one from me, and wants the newest version. These now sell for $79+shipping... but... (here's the loyalty part) For $50 + shipping choice, the new TapTurn is yours if you qualify. I don't need the old unit back, just evidence you're an original customer. (I keep all records). Unhook your gen1 wires and do the flasher plug replacement with Tap Turn gen 2 and you'll get these features: - simple user programmability, 3 to 6 blinks, or OFF completely - can now cancel a blink series that is in progress by tapping again (same direction) - handles LED bulbs, you can remove your load resistors if this applies to you - new hazard modes: wig-wag, and slow motion... and the 3rd hidden mode: slow wig-wag - software factory reset feature - all digital, all new microcontroller based with no analog R-C based loosely based timing parameters - better switch de-bounce that lowers false triggering - easier install, plug-and-play Shipping choices are $10 regular airmail (anywhere world), or $16 tracked (N.A. continent only). PM me to establish your eligibility by submitting some kind of proof. Once that's done, and only after that's done, you'll use PayPal to send the total amount that includes your shipping choice. Link to comment Share on other sites More sharing options...
scottmcphee Posted August 6, 2013 Author Share Posted August 6, 2013 Yes, PayPal or e-transfer (just for Canadians) applies for loyalty program too. PayPal currency will be USD$ but e-transfer will be CAD$, that's just the way it is. Doesn't matter to me about exchange rates of the day - just pay in the currency type of the system you're using. Link to comment Share on other sites More sharing options...
scottmcphee Posted October 2, 2013 Author Share Posted October 2, 2013 I'm playing around with strobe effects, see other thread http://legacygt.com/forums/showpost.php?p=4598811&postcount=181 Link to comment Share on other sites More sharing options...
scottmcphee Posted January 29, 2014 Author Share Posted January 29, 2014 StrobePack is selling well! More ideas in the pipe... soon Link to comment Share on other sites More sharing options...
scottmcphee Posted May 23, 2014 Author Share Posted May 23, 2014 So those ideas came to be: PARKED LIGHTING FEATURES! These things are designed to be used when parked. Directional Park Light - while parked and IGN is off, move signal stalk left or right to illuminate signal bulbs on that side constantly, not blinking. A common Euro feature.. and think about it, uses half the battery power of normal parking lights - and with LED bulbs you can leave it on all night without worry! Arrival & Departure lighting - after using the remote to lock or unlock your Forester, ALL signal bulbs light up for a period of time. (Timer is adjustable, of course.) Helps you see walking around the vehicle when parked in dark places. These lights go off immediately if you start up, or when the time period has elapsed. Link to comment Share on other sites More sharing options...
