Variable Torque Distribution vs. Continuous
VTD is 45/55 rear bias
i think this is the best AWD config for the legacy, since it would accelerate faster
the down side is that it only comes in 5EAT
Continuous is 50/50
which i think is at a disadvantage when accelerating
so couldnt you change the LSD or EM to believe it is a VTD and not continuous?
i know with $$ anything is possible so if you dont know shit go on to the next thread so you can get your post counts up :lol:
anyone ever try, know of anything related to this matter?
i would actually prefer 40/60 rear split but that would mean even more $$
The Subaru 5-speed manual transmissions use a mechanical viscous center differential. I don't think there'd be a good way of changing the front/rear bias.
phoenix96
2006 Legacy GT Ltd · 2011 Outback 3.6R Ltd · 1992 SVX
2006 Outback 3.0R VDC · 2009 Forester 2.5X
2002 Outback VDC · 1996 Outback 2.5L · 1986 GL-10
Just in a general sort of sense, it's not going to accelerate any faster with 40/60, 30/70, or 90/10 unless there is some sort of traction issue under acceleration. As long as all the power is getting to the ground and there is no wheelspin, it will accelerate the same whereever the power is going.
Now, if you are talking about an ideal launch from a dead start, something like that may be more ideal in that you could dial in some wheelspin to prevent bogging off the line. But we are talking either some massive amounts of power for a Legacy, or pretty crappy tires, to be needing that.
The real issue for me towards any torque split is in regards to it's handling at the limits in corners. A little more rear bias would help for turn-in and acceleration out of a corner with less understeer, but that's a black magic sort of thing at best. I don't mind 50/50 at all with the manual tranny legacies because it's at least constant, so there is little to upset the chassis mid-corner. Quite a few circuit race teams used to disable dccd and ayc in the high hp sti's and evo's to eliminate as much torque shifting as possible, as it was easier to setup a chassis for a consistant front to rear torque split.
Cheers,
Paul Hansen
http://www.avoturboworld.com | http://www.sevenphotos.com | http://www.scoobymag.com
