KW Variant 2 Coilovers Installed
Chappy
After a couple of weeks of tweaking and adjusting I think I finally have my KW V2's where I want em. Kelly was great with me from Racecomp Engineering in getting these very quickly and answering all my questions and addressing my concerns. My intial impression of them was that they were firm but not stiff which I liked. After a couple of weeks of settling they still feel the same. They are huge improvement over stock in terms of body roll and confidence in taking turns at speeds that I wouldnt have thought of before. Heavy bumps hit hard but they are not jolting. The KW's absorb very well. I have the preload set to 1.5 turns and that seems perfect. The rear end it very stable and planted. It does not get loose very easily.
I had TDC Tuning do the install and it did not take very long. They used my stock tophats. Install maybe took 2 hours. I had a DP done as well so everything was done in about 3.
I would definately recommend these for someone looking for a very firm ride. They are great on the highway and give a very stable feel up past 100. They are not floaty and will not give you a Cadillac type ride. They are very quiet.
Overall no complaints at all. Racecomp was great to deal with and the KW brand seems to be well established and they make a very impressive product. I would no hesitate buying these again.
Here are some before and after pics. My wheels are SSR 17x7.5 with 225/45's.
Before:
http://img.photobucket.com/albums/v630/WRX05/DSC00011.jpg
http://img.photobucket.com/albums/v630/WRX05/DSC00012.jpg
http://img.photobucket.com/albums/v630/WRX05/DSC00013.jpg
http://img.photobucket.com/albums/v630/WRX05/DSC00014.jpg
After:
http://img.photobucket.com/albums/v630/WRX05/DSC00064.jpg
http://img.photobucket.com/albums/v630/WRX05/DSC00063.jpg
http://img.photobucket.com/albums/v630/WRX05/DSC00062.jpg
http://img.photobucket.com/albums/v630/WRX05/DSC00059.jpg
  • Replies 82
  • Created
  • Last Reply
I ordered these a couple days ago.
I wanted something of quality, but still used a little rubber (e.g. stock or sti top hats)
My IONs will be up for sale.
Your review was vs stock.
I'll give my impressions vs IONs/comfort/body role etc...
Curious if I should use stock or sti top hats.
Did John give any impressions on these? Still have to get an alignment?
Sutter, I still need an alignment altough its not too far off from stock. After installing them, Jon liked the firmness. The overall quality of them amazing. I should easily get 3-4 years out of em before a rebuild. I went with my stock hats. I guess you could use the STi ones as well.
Great Pics!! The car looks great!!
http://img.photobucket.com/albums/v630/WRX05/DSC00064.jpg:wub:
Don’t forget these can be used on the wagons too!!!!
The ssr's look great too.. I think they are my favorite wheel
I am glad you like them. KW is a great company to work with; they have an outstanding product and back it up with excellent customer service!!
Kelly E!
Good to finally get a review (and more coming) of these for the Legacy. I considered getting these a while ago, but travel for work has kept pushing it back. Maybe I'll finally get around to getting them sometime in May. They definitely look like they provide what I'm looking for.
Are the bound and rebound adjustable on these.
They're Variant 2s so they have adjustable rebound damping.
Myles, I just installed my STI pinks I got from you guys and love the ride. What is the bounce that you are talking about. The firmness? I thought the ride dramatically improved with the new springs.
RJO
i am getting IONs, but now i'm concerned about my stock shocks failing within the first year (i drive ~45K miles). The cost of replacing with bilstein struts at this point is just too high (not to mention installation costs, etc. to have the springs transferred to another pair of struts).
now i'm thinking that coilovers are the way to go. chappy, how streetable are the KWs? can they be tuned to give a similar ride to IONs or Htechs?
Well, I've run into a problem installing the coilovers. When installing the upper mount onto the new strut, I can't tighten the upper bolt without having the piston shaft spin. Is there some easy way to secure the shaft so it doesn't spin... or am I just missing something (which it wouldn't surprise me much if I'm just going about it completely wrong...)?
allen wrench or clamp on top and slip a box or closed end wrench.
An allen wrench on top won't work cause there's no spot for one - the rebound adjustment knob is up there. And there's not enough of the upper bolt showing to get any sort of clamp on it....
