AWD_Rules3830 Posted March 28, 2006 Share Posted March 28, 2006 i removed the dealer sticker, well the rubbing alcohol do anything bad to the paint?? I used a blow-dryer and and clean old rag shirt with rubbering alcohol and water to get the residue off I love my car ... basically. Link to comment Share on other sites More sharing options...
Hanger Posted March 28, 2006 Share Posted March 28, 2006 i used nail-polish remover when i did my debadge, seems fine now someone even used gasoline or alcohol forgot... ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
Acil Posted March 28, 2006 Share Posted March 28, 2006 Its my understanding that rubbing alcohol is a paint thinner, but I'm not sure about that.... SELECT * FROM users WHERE clue > 0; 0 rows returned Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted March 28, 2006 Author Share Posted March 28, 2006 Its my understanding that rubbing alcohol is a paint thinner, but I'm not sure about that.... Oh lord dont scare me like that, i read something online that told me to use it either way i will have new pictures of it without the sticker in the photos section in a day or two I love my car ... basically. Link to comment Share on other sites More sharing options...
VTGT Posted March 29, 2006 Share Posted March 29, 2006 What is the best way to debadge then? Link to comment Share on other sites More sharing options...
Acil Posted March 29, 2006 Share Posted March 29, 2006 Oh lord dont scare me like that, i read something online that told me to use it either way i will have new pictures of it without the sticker in the photos section in a day or two The only thing I could find is that its a latex paint thinner... so maybe I'm wrong. either way, if you can't feel or see a difference, its most likely not going to be in issue. SELECT * FROM users WHERE clue > 0; 0 rows returned Link to comment Share on other sites More sharing options...
Acil Posted March 29, 2006 Share Posted March 29, 2006 What is the best way to debadge then? Search is your best friend!!! a quick search turned up this walk through: http://legacygt.com/forums/showthread.php?t=1175&highlight=debadge SELECT * FROM users WHERE clue > 0; 0 rows returned Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted March 29, 2006 Author Share Posted March 29, 2006 What is the best way to debadge then? well you have to heat it up and remove it at a 90 degree angle and this use some sort of a wax and paint safe solvent to remove the residue. You can use 3M adhesive remover, and make sure you dont heat it too much or you can cause problems for the paint. I love my car ... basically. Link to comment Share on other sites More sharing options...
see_obxt Posted March 29, 2006 Share Posted March 29, 2006 GooGone works so does MEK (Methyl Ethyl Keytone) also but don't rub tooo hard. I just used that on the legalease on my luggage racks. Link to comment Share on other sites More sharing options...
AWD_Rules3830 Posted March 29, 2006 Author Share Posted March 29, 2006 GooGone works so does MEK (Methyl Ethyl Keytone) also but don't rub tooo hard. I just used that on the legalease on my luggage racks. A ketone ... interesting, how can you have a methyl ethyl ketone?? oh wait you can. i had to think for a min about the chemical structure. They do teach us something in adv. chemistry class haha. that might be harmful to the paint and wax, i wouldnt suggest it. I love my car ... basically. Link to comment Share on other sites More sharing options...
Th3Franz Posted March 29, 2006 Share Posted March 29, 2006 I told my dealer not to put one on, and they obeyed. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Sponge Posted March 29, 2006 Share Posted March 29, 2006 My dealer put two of the damn things on...they are going to remove them both too My vB Gallery Link to comment Share on other sites More sharing options...
see_obxt Posted March 29, 2006 Share Posted March 29, 2006 I'm glad to know MEK exists... MEK and Goo Gone actually works well as does WD-40 for taking off the rubberized glue off painted surfaces. I say only use MEK as a last resort. Also, test in a hidden spot see how it works. It will work to get real nasty glues, resions off painted surfaces. Sometimes you need to get something off a car surface that will be worse leaving it on than using a solvent. In that case, MEK may be needed. Clean up after and make sure you yse a good wax after. Link to comment Share on other sites More sharing options...
TYNY Posted March 29, 2006 Share Posted March 29, 2006 don't rub too hard, i scratched my clearcoat cause i was too anxious and didn't read the walk-through. Link to comment Share on other sites More sharing options...
