CasopoliS Posted March 13, 2006 Share Posted March 13, 2006 Well it seemed like a boulder, it was huge. I bought an LGT out in Maryland this weekend (well I bought it last week, picked it up over the weekend). On my way back to OH, I hit a huge rock in the hills of PA... I ran it over with the driver's side front wheel. The car did not look damaged at first glance. On my way to work this morning, the tire went flat. After changing it seems the rim is bent and dinged up on the inside, and the tire was torn. The tire place told me it could still hold a seal, and it was just cosmetic stuff. I have not gotten a chance to make sure my axle, brakes, etc are damaged, but it rides and drives fine so far. Tonight I will get under the car. Anyway I was quoted $213 to mount and balance a new tire (same as stock). I left it with the tire place frustrated, figured I would just pay whatever since I need to get off the spare. Also, should I get two tires so the fronts match tread thickness? The tires will be the same Potenzas, and the pass. side has maybe 1/2 tread left. What is sensitive behind the rim that I should look at? Seeing how the inside edge was dinged up, the rock should have hit much more. If I could guess, it was as high as a curb, maybe 6" deep and 8" long, and weighed over 20 lbs. Link to comment Share on other sites More sharing options...
Garandman Posted March 13, 2006 Share Posted March 13, 2006 If you don't want to spend the money on new treads yet, Potenzas go pretty cheap on eBay. I know because I tried to sell some new 225/55r17's for $30 each and got denied..... Who Dares Wins スバル Link to comment Share on other sites More sharing options...
TSiWRX Posted March 13, 2006 Share Posted March 13, 2006 Oh no, bro! I'm so sorry to hear! Like the other guys have said, search around either here or on eBay, you might find a replacement set of the stock RE92s for quite the bargain-basement price. Otherwise, honestly, take this as your God-given sign to move-on to better rubber. Falken ZIEX-ZE 512s are a good all-weather compromise, and are priced very competitively, with your local Sears probably willing to price-match Discount Tire's pricing to-boot. Alternativley, Fuzion ZRi or HRis are also a decent, yet price-conscious bet. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
plunk10 Posted March 13, 2006 Share Posted March 13, 2006 :( Ouch dude. I'm very sorry to hear that. I'm glad you made it back to Ohio safely though. I just wish the legacy had better luck. Also heightsgtltd is correct. A lot of folks do swap out the Bridgestone RE92s for other tires. Of course, I wouldn't switch brands unless you were changing at least 2 tires. edit: here's 4 RE92s from a member in Wisconsin. http://www.legacygt.com/forums/showthread.php?t=27355&highlight=re92 Link to comment Share on other sites More sharing options...
CasopoliS Posted March 13, 2006 Author Share Posted March 13, 2006 Yea thanks for the link. Those tires would be a good deal, but then I would have to pay to ship them, then pay the place to mount and balance which will me more since I am not buying the tire from them. AND I would be driving on the spare a little longer. A good deal, just a little more hassle. If the other 3 tires' tread was a little lower, I would contemplate replacing them... but it is not necessary now. FYI Subaru Roadside assistance came through this morning. Someone came out to put on my spare. I was dressed up for work, and it was tsunami-like rain and mud where I pulled over. I will give you the update when I get home tonight, I really hope nothing will be broken. I need to get my alignment checked too now. ahhhhh. Link to comment Share on other sites More sharing options...
forestir Posted March 13, 2006 Share Posted March 13, 2006 Make sure all tires are within 1/32" tread depth of each other (or 1/4" circumference). This will help reduce the wear and tear on your differentials. This number comes from Subaru. Link to comment Share on other sites More sharing options...
CasopoliS Posted March 13, 2006 Author Share Posted March 13, 2006 Oh wow thanks, I did not know that. That is a very small number. So do you guys rotate tires often to keep tread wear even, or is that not necessary? If I had the money, I would just pick up some new rims and tires from somebody, then sell the stock rims. Link to comment Share on other sites More sharing options...
Beanboy Posted March 13, 2006 Share Posted March 13, 2006 Friends with soobies have noticed tread wear is fairly even, but they aren't aggressive drivers. I usually rotate early spring and late fall. Subaru recommends every 7500 miles I believe. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
Garandman Posted March 13, 2006 Share Posted March 13, 2006 I just use a tire gage and rotate when the wear is noticable. Subarus usually wear the fronts a little faster than the rears. Who Dares Wins スバル Link to comment Share on other sites More sharing options...
plunk10 Posted March 13, 2006 Share Posted March 13, 2006 Jon, just so you know, the tires were last rotated around 15,500 miles. So if you are getting a new tire, you might as well rotate it along with the other front tire to the back. Link to comment Share on other sites More sharing options...
godwhomismike Posted March 13, 2006 Share Posted March 13, 2006 There are so many unhappy people who have cut their loses with the Potenza's, that you might be able to find a set dirt cheap on here. Most of us would probably recommend that you just ditch the Potenza's and buy a set of quality tires. You could get much better tires for half the price of a Potenza RE92. After my experience with them, I will NEVER own another Bridgestone tire again. Link to comment Share on other sites More sharing options...
CasopoliS Posted March 13, 2006 Author Share Posted March 13, 2006 Thanks for the help everyone. Actually if I knew I could sell my stock LGT rims and tires, I would buy the OZ Superllegras that someone is selling on this board. Tomorrow or Wednesday I should know if a tire will still seal to the rim. It looks like it should be able to, the flat was not bent... only the very outer lip. Its almost just like bad curb rash... just on the inside lip. But at that point, the place will have already sold me the tire because it is mounted to my rim. It is almost like I have to buy the tire and see if it works. If it works, just balance the tire and drive off, if it doesnt work... I will have to buy another rim (or new rims) for them to put the new tire on. Link to comment Share on other sites More sharing options...
PeterJMC Posted March 13, 2006 Share Posted March 13, 2006 Where did you buy your car from in MD? Fitz? Link to comment Share on other sites More sharing options...
CasopoliS Posted March 13, 2006 Author Share Posted March 13, 2006 Well I bought it from plunk10, who lives in Upper Marlboro. We met in Laurel, and I drove it around Leesburg Saturday where my relatives live. I saw a black LGT with a grill and black rims that I think is on this forum, but I forget where I was. Link to comment Share on other sites More sharing options...
plunk10 Posted March 14, 2006 Share Posted March 14, 2006 I think patagonian GT has a black one in northern VA. I could be wrong though. Of course now that she's sold, I'm seeing them everywhere . I'm gonna miss her, but I'm glad she's found a good home :) Link to comment Share on other sites More sharing options...
CasopoliS Posted March 14, 2006 Author Share Posted March 14, 2006 Ok so the tire shop cannot mount a tire to the rim. Now I need a new rim and tire. It sucks just looking for 1. Might have to buy a new set of rims and tires and just sell the 3 good ones I have individually or as a whole. Where can I find a cheap rim / tire package? Link to comment Share on other sites More sharing options...
plunk10 Posted March 14, 2006 Share Posted March 14, 2006 that sucks this guy might be able to part out, since he has a lot of various different types of wheels. http://www.legacygt.com/forums/showthread.php?t=29789 Link to comment Share on other sites More sharing options...
CasopoliS Posted March 14, 2006 Author Share Posted March 14, 2006 Yea I will see. I just want to get off this spare tire..... it cannot be good to drive on it. Link to comment Share on other sites More sharing options...
