Deer Killer Posted August 25, 2004 Share Posted August 25, 2004 ? (from the underseat sub) I figure it's best not to hack up the stock connector, plus I bet it has a remote turn on wire. Do you think it's possible to get it by this weekend, and will the price be at stealership levels? Link to comment Share on other sites More sharing options...
rao Posted August 25, 2004 Share Posted August 25, 2004 IIRC, it is not available as a separate part. If it is it will give you a turn on signal and high level speaker signals. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
c_hunter Posted August 25, 2004 Share Posted August 25, 2004 How did you get a sub without the harness?? Craig Link to comment Share on other sites More sharing options...
Deer Killer Posted August 25, 2004 Author Share Posted August 25, 2004 aftermarket sub.. I'm not paying $200 for that thing :) Link to comment Share on other sites More sharing options...
Xenonk Posted August 25, 2004 Share Posted August 25, 2004 I would just use vamp clips, a line converter box, and a high filter crossover if you doing a direct connection from the head unit to the sub.. best off to get an amp to go with it or a powered sub IMO. Keefe Keefe Link to comment Share on other sites More sharing options...
