voyetra8 Posted February 27, 2006 Share Posted February 27, 2006 Everyone seems to talk about doing the first oil change at 3k miles. What would happen if you waited to get it done until 5k? I guess I don't see how it's any different from a regular change, considering the oil filter is catching all of the "metal pieces" that people often mention. Is it because the oil breaks down faster in a new engine? I've always been curious about this.... Link to comment Share on other sites More sharing options...
yamie700 Posted February 27, 2006 Share Posted February 27, 2006 More metal shavings are flying around in a new engine, while everything is still seating in. Most on here will tell you to get the first change at 1000 miles, my dealer even recommended this. Link to comment Share on other sites More sharing options...
rallispec Posted February 27, 2006 Share Posted February 27, 2006 changed mine at 1k really depends though -- i'd suggest doing whatever the manual tells you to do. Link to comment Share on other sites More sharing options...
rao Posted February 27, 2006 Share Posted February 27, 2006 The maintenance schedule has the first and all subsequent oil changes at 7,500 miles (unless you have the H6, which calls for the first oil change at 3,000 miles, then 7,500 and every 7,500). People do it earlier because it makes them feel better. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted February 27, 2006 Share Posted February 27, 2006 had mine done @ 3k miles. Using standard oil still. Not going to switch to synthentic till after 10k miles. just my 2 cents. Link to comment Share on other sites More sharing options...
iyalla Posted February 27, 2006 Share Posted February 27, 2006 had mine done @ 3k miles. Using standard oil still. Not going to switch to synthentic till after 10k miles. just my 2 cents. Exactly what I did. I'll be switching to synthetic in the summer heat around that mileage too. Might go to semi-syth on the second change to prep. Link to comment Share on other sites More sharing options...
voyetra8 Posted February 27, 2006 Author Share Posted February 27, 2006 People do it earlier because it makes them feel better. About what I figured. Link to comment Share on other sites More sharing options...
yamie700 Posted February 27, 2006 Share Posted February 27, 2006 My salesperson is a co-driver for a rally team and he was the one who suggested I get it changed at around 1k. He has been dealing with subaru engines for years so I figured I would trust him. It doesn't hurt to change it early but it could hurt to change it late:) Link to comment Share on other sites More sharing options...
HansGT Posted February 27, 2006 Share Posted February 27, 2006 minimum 3K. let the seals set. especially if you switch to synthetic. Synthetic oil has smaller molecules so if your seals are not set the synthetic could get places you don't want it. or go with the Subaru maintenance schedule of every 7,500. Link to comment Share on other sites More sharing options...
HansGT Posted February 27, 2006 Share Posted February 27, 2006 My salesperson is a co-driver for a rally team and he was the one who suggested I get it changed at around 1k. He has been dealing with subaru engines for years so I figured I would trust him. It doesn't hurt to change it early but it could hurt to change it late:) early could hurt...if it's the 1st one. Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted February 27, 2006 Share Posted February 27, 2006 Main thing to remember for people buying these cars new is the "break-in" time is where small particals of junk can get into the oil due to the engine warming/cooling/expanding and such. This is no different than any other car but regardless, it's good to get it done sooner rather than later. Subaru engines are built for 300,000+ miles. I have no doubt that the engine itself will last that long. The turbo on the other hand... might not. Link to comment Share on other sites More sharing options...
HansGT Posted February 27, 2006 Share Posted February 27, 2006 Main thing to remember for people buying these cars new is the "break-in" time is where small particals of junk can get into the oil due to the engine warming/cooling/expanding and such. This is no different than any other car but regardless, it's good to get it done sooner rather than later. Subaru engines are built for 300,000+ miles. I have no doubt that the engine itself will last that long. The turbo on the other hand... might not. who want the stock turbo for 300,000 miles anyway. Link to comment Share on other sites More sharing options...
yamie700 Posted February 27, 2006 Share Posted February 27, 2006 minimum 3K. let the seals set. especially if you switch to synthetic. Synthetic oil has smaller molecules so if your seals are not set the synthetic could get places you don't want it. or go with the Subaru maintenance schedule of every 7' date='500.[/quote'] Forgot to mention the synthetic thing, my salesguy also recommended not switching to synthetic until about 10k for the reason above. Link to comment Share on other sites More sharing options...
voyetra8 Posted February 27, 2006 Author Share Posted February 27, 2006 Main thing to remember for people buying these cars new is the "break-in" time is where small particals of junk can get into the oil due to the engine warming/cooling/expanding and such. What about the oil filter? Its job is to collect that crap, no? Link to comment Share on other sites More sharing options...
RabidMonk Posted February 27, 2006 Share Posted February 27, 2006 The filter does collect particles during break-in. However, the bypass valve in that filter opens when you put the engine under heavy load, so those particles have a chance to recirculate. Link to comment Share on other sites More sharing options...
HansGT Posted February 27, 2006 Share Posted February 27, 2006 Forgot to mention the synthetic thing, my salesguy also recommended not switching to synthetic until about 10k for the reason above. yeah...not sure how much the dealerships know. I did mine at 3.2K...switch to sythetic. One guy said wait till 7.5K, the tech said I could do it right away. heck on auto trader there are two legacy gt's for sale listed to have V6 engines. do a search, someone on here got an "offical" SOA view on synthetic oil and when to change. Link to comment Share on other sites More sharing options...
rc0032 Posted February 27, 2006 Share Posted February 27, 2006 I do it @ 3,000 because I like to feel good Moved to long-term maintenance. Link to comment Share on other sites More sharing options...
tundwgn Posted March 9, 2006 Share Posted March 9, 2006 Everyone seems to talk about doing the first oil change at 3k miles. What would happen if you waited to get it done until 5k? I guess I don't see how it's any different from a regular change, considering the oil filter is catching all of the "metal pieces" that people often mention. Is it because the oil breaks down faster in a new engine? I've always been curious about this.... The engine (breaks-in) during the first 1000 miles and it's imperitive to get all that worn piston/cylinder lining metal out of your circulating oil system. Most of the debris created during break in is so fine that it doesn't effectively get filtered. Since most engines are riding on about 10 microns of a film or oil give or take, one should really overdo it in the beginning. I changed mine at a shade under 900 mi., then again at 3000 mi., then again at 5849 mi. Probably too much for most people. Plus it's more costly, but it makes me sleep better knowing my oil system is completely flushed of all that crappy mineral based oil that SOA puts in engine from factory. Link to comment Share on other sites More sharing options...
