tekkitan Posted February 22, 2006 Share Posted February 22, 2006 Yes today I got the dreaded check engine light (dreaded for me anyways). It has gone on before. I go around this curve on the highway on my way home from work, and when I come out of the curve sometimes my CEL will start flashing then stop after a few seconds. Today it started flashing in the same place, then stayed solid. It is still solid. I checked my oil, it's full. It seems to run alright, so I was wondering if anyone knew what could be the problem and give me some things to check before I take it in. It's a 2000 Legacy GT Limited (2.5L no turbo) Link to comment Share on other sites More sharing options...
tekkitan Posted February 23, 2006 Author Share Posted February 23, 2006 I got a pocket OBDII scanner. Cylinder 1 Misfire Detected. Link to comment Share on other sites More sharing options...
Aczwild Posted February 23, 2006 Share Posted February 23, 2006 I'd say its time to go to the dealer then if there is a misfire detected You may want to get a Cylinder Compression check done JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
forestir Posted February 23, 2006 Share Posted February 23, 2006 Quite odd though, that it happens only on that curve--unless that happens to be your favorite curve where you really get on it. I was stumped. Link to comment Share on other sites More sharing options...
Flanders Posted February 23, 2006 Share Posted February 23, 2006 Could be headgasket time for you. If the CEL light blinks apparently it is very serious, solid CEL means keep on truckin. Link to comment Share on other sites More sharing options...
tekkitan Posted February 24, 2006 Author Share Posted February 24, 2006 Well I cleared the code and drove it today. Drives as good as it ever did. I'll check the spark plugs and all this weekend. forestir: i do get on it out of the curve when it happens today i eased up on it out of the curve though. Link to comment Share on other sites More sharing options...
SLegacy99 Posted February 24, 2006 Share Posted February 24, 2006 This just happened to me. Cylinder misfire due to incorrect spark plugs. So if you recently had them replaced could be that. Link to comment Share on other sites More sharing options...
stanjk3 Posted February 25, 2006 Share Posted February 25, 2006 What spark plugs did you put in?? I tried Bosch Platinums and had misfires after 6 months. Now have NGK V-power spark plugs in the Legacy, AC Delco Rapidfires in my GA. Have been happy with both. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
SLegacy99 Posted February 25, 2006 Share Posted February 25, 2006 The previous owner of my Legacy put in Bosch plugs that werent platinum!!!!! WTF! So I now have the NGKs and the power difference is considerable. Link to comment Share on other sites More sharing options...
Flanders Posted February 25, 2006 Share Posted February 25, 2006 The only plugs I know by name that I have run are Denso Iridium which I put in 1 year ago. Honestly, I think this is the first time I have had the plugs changed and that was at 80k. I'm now at 105k and my man said they look good. Link to comment Share on other sites More sharing options...
stanjk3 Posted February 25, 2006 Share Posted February 25, 2006 Forgot to mention the car also still had the original spark plug wires, that's ~10.5 years, and the plugs had about double the gap they were supposed to. Ran a lot smoother, and pickup was worlds better after we changed them. There's no point in putting "high end" plugs in an 11yr old car, or any other car, unless you have engine mods to actually make use of them. Friends don't let friends drink cheap beer. Link to comment Share on other sites More sharing options...
GTsleeper Posted February 26, 2006 Share Posted February 26, 2006 with CEL flashing & not happening all the time i would look at plugs/or wires, or even a injector, pooping then spraying. not compression/ or head gasket. tekkitan- i live right next to ya if u need help. my # on our local site if u want to give a call or pm me. Link to comment Share on other sites More sharing options...
